NVIDIA GeForce GTX TITAN PG600 Schematic & Board View
    The GeForce GTX TITAN was an enthusiast-class graphics card by NVIDIA, launched on February 19th, 2013. Built on the 28 nm process, and based on the GK110 graphics processor, in its GK110-400-A1 variant, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_0, which can be problematic with newer DirectX 12 titles. The GK110 graphics processor is a large chip with a die area of 561 mm² and 7,080 million transistors. It features 2688 shading units, 224 texture mapping units, and 48 ROPs. NVIDIA has paired 6 GB GDDR5 memory with the GeForce GTX TITAN, which are connected using a 384-bit memory interface. The GPU is operating at a frequency of 836 MHz, which can be boosted up to 876 MHz, memory is running at 1502 MHz (6 Gbps effective).
    Being a dual-slot card, the NVIDIA GeForce GTX TITAN draws power from 1x 6-pin + 1x 8-pin power connector, with power draw rated at 250 W maximum. Display outputs include: 2x DVI, 1x HDMI 1.4a, 1x DisplayPort 1.2. GeForce GTX TITAN is connected to the rest of the system using a PCI-Express 3.0 x16 interface. The card's dimensions are 267 mm x 111 mm x 38 mm, and it features a dual-slot cooling solution.
    GTX TITAN PG600​
    NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
    The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
    10-02-2024, 08:52 AM
    NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
    The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
    10-02-2024, 07:51 AM
    NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
    The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
    10-01-2024, 01:54 PM
    NVIDIA GeForce RTX 4080 (RTX4080) Schematic & Board View
    The GeForce RTX 4080 is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2022. Built on the 5 nm process, and based on the AD103 graphics processor, in its AD103-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 4080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The AD103 graphics processor is a large chip with a die area of 379 mm²...
    10-02-2024, 08:57 AM
    NVIDIA GeForce RTX 3070 Schematic & Board View
    The GeForce RTX 3070 is a high-end graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA104 graphics processor, in its GA104-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3070. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA104 graphics processor is a large chip with a die area of 392 mm² and 17,400 million...
    10-02-2024, 08:48 AM
