NVIDIA GeForce RTX 4070 (RTX4070) Schematic & Board View
    The GeForce RTX 4070 is a high-end graphics card by NVIDIA, launched on April 12th, 2023. Built on the 5 nm process, and based on the AD104 graphics processor, in its AD104-250-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 4070. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The AD104 graphics processor is an average sized chip with a die area of 294 mm² and 35,800 million transistors. Unlike the fully unlocked GeForce RTX 4070 Ti, which uses the same GPU but has all 7680 shaders enabled, NVIDIA has disabled some shading units on the GeForce RTX 4070 to reach the product's target shader count. It features 5888 shading units, 184 texture mapping units, and 64 ROPs. Also included are 184 tensor cores which help improve the speed of machine learning applications. The card also has 46 raytracing acceleration cores. NVIDIA has paired 12 GB GDDR6X memory with the GeForce RTX 4070, which are connected using a 192-bit memory interface. The GPU is operating at a frequency of 1920 MHz, which can be boosted up to 2475 MHz, memory is running at 1313 MHz (21 Gbps effective).
    Being a dual-slot card, the NVIDIA GeForce RTX 4070 draws power from 1x 16-pin power connector, with power draw rated at 200 W maximum. Display outputs include: 1x HDMI 2.1, 3x DisplayPort 1.4a. GeForce RTX 4070 is connected to the rest of the system using a PCI-Express 4.0 x16 interface. The card's dimensions are 240 mm x 110 mm x 40 mm, and it features a dual-slot cooling solution.​
    RTX4070
  • Much Bugs
    • Apr 2025
    • 34
    • China
    Another two schematic and boardview of Asus and MSI 😉:
    • jonelin
      • Apr 2025
      • 5
      • china
      thank you for share my bro​
      • renzkie33
        • Mar 2022
        • Malaysia
        thanks a lot
