AMD Radeon RX 7900 XT (RX7900XT) Schematic & Board View
    • 115472
    The Radeon RX 7900 XT is an enthusiast-class graphics card by AMD, launched on November 3rd, 2022. Built on the 5 nm process, and based on the Navi 31 graphics processor, in its Navi 31 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 7900 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 31 graphics processor is a large chip with a die area of 529 mm² and 57,700 million transistors. Unlike the fully unlocked Radeon RX 7900 XTX, which uses the same GPU but has all 6144 shaders enabled, AMD has disabled some shading units on the Radeon RX 7900 XT to reach the product's target shader count. It features 5376 shading units, 336 texture mapping units, and 192 ROPs. The card also has 84 raytracing acceleration cores. AMD has paired 20 GB GDDR6 memory with the Radeon RX 7900 XT, which are connected using a 320-bit memory interface. The GPU is operating at a frequency of 1387 MHz, which can be boosted up to 2394 MHz, memory is running at 2500 MHz (20 Gbps effective).
    Being a dual-slot card, the AMD Radeon RX 7900 XT draws power from 2x 8-pin power connectors, with power draw rated at 300 W maximum. Display outputs include: 1x HDMI 2.1a, 2x DisplayPort 2.1, 1x USB Type-C. Radeon RX 7900 XT is connected to the rest of the system using a PCI-Express 4.0 x16 interface. The card's dimensions are 276 mm x 110 mm x 51 mm, and it features a dual-slot cooling solution.
    GV-R79XTGAMING
    RX7900XT​
  • WTFRules!
    • Feb 2023
    • 25
    • Argentina
    Thanks!
    • jf5284
      • Jan 2025
      • china
      thx bro
      • kewltek1
        • Jun 2025
        Thank you Bro.
          AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
          The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
          10-01-2024, 12:46 PM
          AMD Radeon RX 6800 XT (RX6800XT) Schematic & Board View
          The Radeon RX 6800 XT is a high-end graphics card by AMD, launched on October 28th, 2020. Built on the 7 nm process, and based on the Navi 21 graphics processor, in its Navi 21 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 6800 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 21 graphics processor is a large chip with a die area of 520 mm² and 26,800...
          10-01-2024, 12:17 PM
          AMD Radeon RX 5600 XT (5600XT) Schematic & Board View
          The Radeon RX 5600 XT is a performance-segment graphics card by AMD, launched on January 21st, 2020. Built on the 7 nm process, and based on the Navi 10 graphics processor, in its Navi 10 XLE variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 5600 XT. The Navi 10 graphics processor is an average sized chip with a die area of 251 mm² and 10,300 million transistors. Unlike the fully unlocked Radeon RX 5700 XT, which uses the same GPU but has all 2560 shaders enabled, AMD has disabled...
          10-01-2024, 10:42 AM
          Radeon HD 7900 C387PI 59YV03H0 VG0A03S Boardview
          HD7900...
          10-29-2024, 03:36 AM
          AMD Radeon HD 7900 GPU C381 Boardview
          59YV01P0-VG0A13S Rev 1.00A...
          10-27-2024, 02:14 AM
