#1 |
hi new here hope you can help
Got Polaroid 22inch led tv number tlac 02255 ,move tv to another room and turned it on it did not turn on no power,no stand by light came on, only had tv 6 months (no warranty got it from target clearance sale ) ok nothing to lose i open tv up and checked power cable looked ok,checked capacitors and one was not right so i changed it used a 35 volts one instead of the 16 volts one that was in tv checked the ir sensor board and when i touched the soldering parts with finger i notice the ir sensor ( red for standby on blue for tv on)the sensor light turned dull blue sometimes i got red but when i stopped touching the soldering parts if went off , now the weird bit i put the sensor board down on the aluminum cover the hides the inverter with soldering joints face down to the aluminum and the red light came on bright and stopped on picked it up and it stayed on so i tried turning tv on with button and the tv came on ??, powered off tv and tried again did not work,i on tried turning on again but could not get red light on but got bluedull flashing everytime it touched the aluminum cover then after 3-5 times it would not flash ,i turned power off then left it 10 mins and tried again , the red light came on and tv worked , but tried it many times since but no red light but i get the blue dull light coming on,any ideas what it could be i can post pics if want , Ok do you thing it is the sensor board that it not working ?? shame to throw a 6 month tv away due to a sensor board and would i be able to go and get it fixed ?? any help would be appreciated |
#2 |
City & State: University of Leeds (MEng ElecEng undergrad)
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
What capacitor did you use to replace the failed one and where did you get it?
#3 |
it was on the main board ,underneath it looked bad and had a little bulge on top was a 220uf 16 volts and use a 220uf 35 volts to exchange from radioshack would that still be the problem . i am a noob with electrics but i did my bigger tv (3 capacitors blew and that worked )
#4 | |
My Country: UK
I'm a: Student Tech
#5 |
ty tom 66
so you think it could be the capacitor i put on ??? i could change the capacitor and see if it was that but if not what else could it be . |
#6 | |
My Country: UK
I'm a: Student Tech
Have you tested the output voltages of the power supply? Do you have a multimeter? |
#7 |
bro in law got one but how do you test voltages ??? |
#8 | |
My Country: UK
I'm a: Student Tech
Connect the black probe to an exposed part of the metal cage. On the connector which goes to the main board from the power supply, probe each pin. Record all the readings. Note down if any seem to vary quite a lot. |
#9 |
got a new problem, bro in law was checking voltages etc and looks like the (think its a fuse) fuse blew now i dunno if that's was the first problem or what he did not get chance to check alot due to fuse i just clutching at straws with this tv learning as i go as i love to take it to tv repair shop but they will charge me (i bet) $25 + just to look at it or will they give me a free estimate ( i would spend $50 on it if they can fix it as tv was new but got it for $100 weird just one little capacitor or fuse can kill a tv well this one don't even go on standby light now if it did i bet people could tell me the problem but now well i keep trying
is that the number of the fuse above (in pic) i try replace it and see what happens but i think we have same prob , so noone knows what the problem could be ??(before fuse blew)what sort of fuse(if fuse) is that? ty tom for your persistence with me ![]() and before the fuse went bro in law touch something in here see below and light come on the tv. ![]() |
| Thread Tools | |
| Display Modes | |
