When displays go it is usually either:
1. the power supply (especially the caps)
2. the inverter
3. the bulbs
For the first one swapping out the caps makes the most sense, but for 2,3 I'm beginning to wonder if at some point it may not make more sense to retrofit LEDs than to repair the CCFL electronics/bulbs. Companies are starting to make kits for this, for instance:
http://www.lcdparts.net/XB_Industrial.aspx
and there are sources for strips of surface mounted LEDs, example:
http://www.ledwholesalers.com/store/...ewCat&catId=66
http://www.lilyleds.com/productdetai...&categoryid=57
These are still fairly expensive though. The one thing I have not found yet is a source for the LEDs that are going into displays now. These seem to all be traded within China between various OEMs with no place to buy them directly.
Basically the repair I am imagining would be something like:
1. cut inverter out of the circuit (in some displays, this would be just removing a separate board.)
2. fool the logic into thinking the inverter was still there (there is usually a feed back loop of some sort, and if this isn't done the power supply will shut down.)
3. wire the LEDs directly to the power supply (match voltage of strip to whatever LED supplies).
The main problem would be that there would be no control of the brightness. The XB kit may (or may not) address that since it has a replacement board that goes in where the inverter was in a laptop. For a desktop retrofit there would need to be a little circuit added to convert the brightness voltage (on one pin into the inverter) into, most likely, a duty cycle change on a FET driving the LEDs. For models with a separate inverter there would be space for it where the inverter came out. For models with single board PS/inverter it isn't clear where this piece would fit.
Thoughts? Anybody here done this? Google for "LED display retrofit" and there are a few pages around for some home grown attempts at this.
2. the inverter
3. the bulbs
