Replacement caps, ESR/Impedance/Ripple
    I need to replace a capacitor in my LCD display (ViewSonic VP930b), in the power supply, well look like it . But I'm not familiar with ESR/Impedance/Ripple specs.
    Original caps:
    -CapXon KF (http://www.capxongroup.com/files/KF%...1767828587.pdf)
    -1000uF
    -16 V
    -105°C
    Questions:
    -Ripple: Do I need the same value?
    -ESR/Impedance: Do I need the same value? Lower is better?
    I think I need the same value for the ripple but Impedance I can go with the same or lower value but I'm not sure.
    Thanks,
    Neurotox
    Re: Replacement caps, ESR/Impedance/Ripple
    The Ripple spec tells you how much Ripple Current the cap can handle without over heating internally. [Similar to a current rating on a wire.]
    ... You want the same value or higher.
    ESR/Impedance tells you how much 'resistance' [technically the wrong word] the cap has to passing Ripple Current through it. ['Resistance' to Ripple.]
    Since the caps job is to pass Ripple to ground a low 'resistance' to Ripple it is good.
    ... You want the same value or lower.
    Mann-Made Global Warming.
    - Dr Seuss
      Thanks!
