Hello, I'm the original owner of a Sceptre X24WG (24 inch of course) monitor and it started having trouble 18-24 months ago... I set it aside for awhile and tried it again the last week or so. I get a nice picture when it's first turned on, but I have a green vertical line on the right side of the LCD. See the pictures. When it first went out, after it had been off for a few days, I tried it again and thought it was working and then after awhile it would go out again.
I have tried to read up on the forum here before I posted my problem. I have a lot of pictures and I took voltages from the 11 pin connector. Hopefully I'm providing good details as a new guy here on the forum.
After the monitor has been on a while, it will start to get some pixels in the lower part of the display that turn green... random on the display and then after awhile the display with flash a bit and then eventually go off. It may work for 30-60 minutes.
The pictures of the caps etc... are below... I hope I didn't post too many pictures and I tried to keep them less than 1meg each.
Here are the cap details and voltage details (two different monitor resolutions and the monitor really had not been on very long) The caps all look fine and I'm not seeing any discoloration on the board or any solder joints that look suspecct or cold.
Any suggestions would be helpful! When I found this forum, it motivated me to try and fix the board. Why not right... Thanks, Matt
Caps as identified on the board:
#1 C551 470uF 16v
#2 C552 470uF 16v
#3 C553 470uF 16v
#4 C554 470uF 16v
#5 C662 470uF 25v
#6 C5 470uF 25v
#7 C507 470uF 16v
#8 C210 33uF 35v
#9 C114 TAICON specs?
CN500 Voltages Starting Pin #1 closest to corner of board.
Monitor hooked up and on at 1280x1024 resolution analog
Pins:
1 2.4v
2 78mv
3 86mv
4 4.6v
5 4.38v
6 0v
7 0v
8 0v
9 5v
10 5v
11 5v
At 1900x1200 resolution analog input (not sure this matters but I checked again):
1 2.4v
2 78mv
3 82mv
4 4.4v
5 4.38v
6 0v
7 0v
8 0v
9 5v
10 5v
11 5v
Pictures:
#1 C551 470uF 16v
#2 C552 470uF 16v
#3 C553 470uF 16v
#4 C554 470uF 16v
#5 C662 470uF 25v
#6 C5 470uF 25v
#7 C507 470uF 16v
#8 C210 33uF 35v
Pins:
1 2.4v
2 78mv
3 86mv
4 4.6v
5 4.38v
6 0v
7 0v
8 0v
9 5v
10 5v
11 5v
1 2.4v
2 78mv
3 82mv
4 4.4v
5 4.38v
6 0v
7 0v
8 0v
9 5v
10 5v
11 5v
Pictures:
