Hi Everyone,
Firstly, as this is my first post here. I'd just like to take the time to thank everyone here for their vast wealth of knowledge that can be found on this site. It has made for very interesting reading.
The fault I am looking for help with is that I am getting a blue solarized effect across the whole screen. It seems to be concentrated on darker areas of the picture. (As shown in attached picture).
I have tried a factory reset from the standard menu with no change.
I have a code to enter an installation mode, ie. hold down menu - 1105 OK.
But there is little to change in this menu. (Hotel Mode etc)
I know this fault can occur when the AV board is set to output to a different size of panel, but I can't find a service menu that allows me to change this.
I have been reading up on here a fair bit and from my research I believe I may have a faulty control / T-Con board? Could anyone help me to confirm this?
I have re-seated all cables between all boards (apart from the ribbons between the Y-Sus & Buffer boards / Z-Sus & Buffer Boards.
I have tested the Vs & Va Voltages.
Recommended Settings Vs - 68 / Va - 194
Actual Voltage Found Vs - 64 / Va - 201
I have adjusted the voltages so that they are now correct. However, this has had no effect on the picture.
There are 4 adjustment controls on the Y-Sus which for the moment I have left well alone.
There are 2 LED's on the control board itself. One of which stays on permanently. The other does a long blink, followed by a short blink and then repeats in cycles of 2.
I know that the LED's can sometimes read out error codes, however I'm not sure if this is just normal operation?
The chap this TV has come from has informed me that the AV Board was faulty, but from what I have been reading, this seems unlikely. Could anyone help confirm this? I don't think he was a particularly technical person.
There are plenty of Control / T-Con Boards available second hand for reasonable prices so i am happy to replace it. I just thought I would check with people here to see that it is the most likely culprit before shelling out the money.
Any help, advice or guidance would be very greatly appreciated!
Many Thanks,
Regards,
George.
Many Thanks,
Regards,
George.
