The capacitors I removed I could see that there were five that were bad.
However the repair did not fix my problem, before I repaired the monitor it had a dark screen and the blue lite on the front of the monitor would flash. After the repair I got the message on the screen that the analog signal was missing and the blue lite stayed lit. When I installed the monitor cable the same problem with dark screen and flashing blue lite. I am unable to bring up the menu options also. The capacitors did correct some problems because I never got the no signal message before. There is still a problem in the signal circuit that feeds the video card, would you know what it could be. Without an electrical drawing I have no way of reading correct voltages.
