Benq G2400W 2 second to black problem
    Re: Benq G2400W 2 second to black problem
    Originally posted by hechacker1 View Post
    It's secure. The shrink wrap is also holding it in place. No amount of tugging is going to detach the wire.
    Then it's not a wiring issue.
      I'm glad alexanna stepped in because he is the king in this area. Plus, I had to leave and go outside in freezing -28C weather for a few hours.
      --- begin sig file ---
      --- end sig file ---
        I feel for you. It;s 7°C here right now.
        PlainBill
          Any thoughts on what I can do next? I'm kinda wary about buying new CCFLs since there's some doubt that they're bad.
          And I'd have to buy larger diameter sized ones to get the length I need, or custom ones (which is beyond what I'm willing to pay to repair it).
            You really need to rule out bad CCFLs,Unfortunately with a 24 inch monitor you will not be able to substitute smaller length CCFLs for testing.
            It is very rare for all 4 CCFLS to be causing your problem.
            Just because you see blackened ends on the CCFls does not always mean they are causing the shut down.
            I have in the past measured the CCFL return voltages and found problems. If your DMM has a min/ max record feature we may be able to pick up something, particularly if each CCFL has its own coil.
