Benq FP731
    Re: Benq FP731
    I am no nearer solving this problem now than I was a week ago!
    Everything listed so far has been done, but still the 2 secs to dark persists.
    My question is how should I progress from here?
    Will.
      Re: Benq FP731
      Will.
      Try hooking up a known good set of CCFLs, if you haven't done so.
      The problem COULD be in the sense circuitry; I don't even want to go there.
      PlainBill
        Re: Benq FP731
        I don't have any Parts that I can swap.
        The lamps work, although briefly. How could it be both of them at fault?
          Re: Benq FP731
          Are you using a fuse for the inverter,or do you still have the 1157 bulb installed?
            Re: Benq FP731
            I'm still using the bulb as I haven't ordered a replacement fuse yet.
            I'm waiting to see if I need to purchase anything else.
              Re: Benq FP731
              I have not tried using the light bulb as a simulated load,but I wonder if the light bulb may be reducing the available voltage to the inverter causing the 2 sec problem now.
              If it were me I would try a fuse and see what happens.
                Re: Benq FP731
                I've substituted the bulb with a domestic 3A fuse.
                This time the lights only come on once instead of twice and then go out.
                  Re: Benq FP731
                  If you disconnect all but one CCFL will it light for a few seconds? Try this with all four CCFLs.
                  The design of the inverter is such that any one bad CCFL will cause all to shut down.
                  PlainBill
                    Re: Benq FP731
                    I think it's time for a new monitor!
                    In attempting to gain access to the lamps, one of the ten ribbon cables to the screen tore away!
                    Even though I was especially careful as I knew they were delicate, to my disbelief it still happened.
                    I would therefore like to thank PlainBill & alexanna for their help.
                    Maybe next time I'll do better.
                    Regards,
                    W1ll.
