Hyundai L90D - No OSD
    I've searched the forums using "L90" as my search string and found only one entry not related to my problem, so if this has been covered, I apologize in advance.
    My monitor was working fine until I moved. I used the original box the monitor came in for the move.
    Symptoms:
    Unit powers on and stays on, backlight does come on, "Menu" does not show, and no video appears from known good source. Tapping the back of the unit smartly causes a "white flash" on the screen. Disconnecting the SVGA cable yields a blue screen after a minute or so. I do not own a DVI cable to test that input. While connected, the unit does sense a video presence as the LED stays green until I shut down the PC, then it changes to amber.
    It's been 12+ years since I've repaired consumer electronics, and LCD screens were a dream to own at the time.
    Any ideas on where to begin troubleshooting on this one?
    Many thanks,
    TXShooter
    Re: Hyundai L90D - No OSD
    I would take it apart, clean and reseat all the connectors. If that doesn't work, then post clear focused top down view of all your boards following my sig file below EXACTLY.
    --- begin sig file ---
    --- end sig file ---
      Cleaning the connectors worked!!!! Thanks!!!
