HG281D Backlight Adjustment?
    I have a HG281D 28" LCD that I just purchased on eBay that came back from Hanns-g repair. The monitor works fine, BUT the backlight brightness is all the way up to 100% and it is still not near as bright as my older same exact monitor.
    I have compaired every menu setting from my older monitor to this one and they are setup the same.
    My question is: Is there an internal adjustment for the brightness?
    Thank you.
    Re: HG281D Backlight Adjustment?
    Does it have auto backlight brightness?
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
      Not that I know about. How could I tell if it does?
        I may have a failing inverter board issue, not sure.
          Should be an option in the menu to switch it off if it has it.
