Just joined, see I'm asked to post at least one message ASAP, this is it. Hello everyone.
No real questions. The reason I came here: I have an 8-year-old Gigabyte GA-8KNXP (rev 1) running off an 8-year old PSU that came with a case. Never given any trouble until recently. It's not a terribly slow machine for my purposes despite its age (2400MHz hypertheading Northwood, 4GB ECC RAM); mainly used as RAID file server with WinXP (patched to support software mirroring). A couple of weeks ago it began not to start when switched on from cold; never started first time, but eventually started and booted (I would leave it on for a minute in case it needed to warm up in some way). I decided, in my wisdom, that the PSU caps must be getting tired, and replaced the PSU. On putting the replacement in, I'm not getting any startup (no startup=no BIOS display, no beep, no disc activity). I saw a few electrolytic capacitors in the motherboard that looked possibly a bit bulged and possibly with signs of past leakage (dried-up). I'm going to clean the machine a bit to see if it's really leakage, look for stupid things like forgetting the 12V2 connector (no I didn't) and decide what to do. Repairing an 8-year-old computer seems a bit of a waste of time. I've got the necessary tools (ESR meter, POST card, PSU tester, etc.), but just don't feel like doing this.
Very glad I'm using software RAID; if I used motherboard RAID might not be able to access data without repairing/replacing with similar motherboard (though it's all backed up in at least two places).
Anyway, I'm searching this forum for "8knxp". Not found much yet, but just started; I think it missed the capacitor plague.
Tip from the old days: if your machine is set up to boot from floppy disc, you can see the basic bits (PSU, motherboard, RAM) are working by removing all cards including display card and disconnecting all drives except floppy, putting in a boot floppy, and seeing if the machine seems to access it as expected (light flashing, floppy noises). I'm not totally sure that a modern machine will work happily this way.
Anyway, this message basically says hello.
pol098
pol098
