Here's a general observation of the issue : Immediately when plugged in it tries to power on ( relay clicking ) fails then goes into standby at which point if the power button is swiped will try to power on again , fail and then remain in that state without going back into standby . Visual check of power supply components seems good with the exception of a buzzing sound coming from the general area of VD812 which has SP933 and B2545G printed on it . Backlight flashing momentarily ( intermittent ) along with clicking relay . I repaired a Hitachi with similar issue by replacing the mainboard ... the difference being that the backlights would come and and stay on indefinitely .
Bought a Proscan 55LC55S240V69
Re: Bought a Proscan 55LC55S240V69
Originally posted by christo499 View PostBut sticking with your advice does anyone know of a replacement for that capacitor ?
quick glance... see post #62 onward.
or this thread:
https://www.badcaps.net/forum/showthread.php?t=25679
they suggest taking a look at C857Last edited by traderx; 10-24-2013, 10:32 PM.
I decided to buy a working parts tv with a cracked panel instead of fixing the power supply : LG 55LH400C . If anyone has a direct reference to the panels being the same I'd appreciate it . The Tcon board is the same in both models so I assume the panel is the same . I haven't bought the parts TV yet .
The PSU will NOT be the same, but you could always just swap the Proscan LCD panel into the LG.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
If the t-con board is the same there should be no issue. Only concern could be mechanical mounting positions for panel being slightly different.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
