Came out and found monitor in sleep mode, attempted to turn on with only the led indicator functioning, found cap bubbled up replaced 1000uf 10v with 1000uf 35wdc now it at least turns but has 2 sec light up and fail. but now the led will stay lit. the lower half of the screen is a bit darked out...Any ideas???
Acer AL 2016
Re: Acer AL 2016
Probably a failed driver; possibly you failed to hook up the CCFLs properly.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Re: Acer AL 2016
Originally posted by hydafl View PostI marked the ccfl's as I unplugged them but will recheck them. How do I go about the driver situation? What to look for?
Beyond that, pictures help us help you. Some monitors use surface mount FETs soldered to the board. Others use through-hole FETs. Some use FETs in 8 pin DIP packages.
Pictures of at least 1000 x 1000 pixels are best. Attach them using 'Manage Attachments' - below the text entry area.
