Hi, I have a 1 year old 19in LCD screen that works perfectly fine for 2-10 seconds and the backlights shut down. No sign of bad caps. I did an intense visual inspection. Many people have had this problem and a solution has never been posted. When the lights shut down I can still see info on the screen. It has to do with the backlights power regulation. I tested the voltage across several cap points on the board and it jumps from high 14v to low 14v.
I'm going to swap the 1000uf 25v with a radio shack 1000uf 35v. I saw it solves the problem on fixya. Is this safe? What would happen if I used a 1000uf 50v. I decided the biggest cap 1000uf 25v is for the backlights which seem obvious to need the most power.
Any advice would be great.
