okay so kind of an interesting question may be stupid but here goes. I couldn't help but notice that the inside of this TV is very similar to the st. Series and the ut series minus the main board with the 3d capability. If I were to buy a 3d main board for this TV and install it would it work.? It looks like the panels and sustains are identical. what's the main difference in panels?
panasonic TC-P50U50 3d conversion?
Re: panasonic TC-P50U50 3d conversion?
Well did more research. This tc-p50u50 uses same everything except the mainboard. Its a standard 2d non smart capability. The tc-p50ut50 is essentially the same tv with a different base stand and mainboard and back cover. If I replace the mainboard with that of a tc-p50ut50 do you all think it will work? Im going to get the stand and blue tooth dongle from a cracked screen tc-p55ut50.
My question isthe 55 inch version uses the same sustain board for boards and all internals as a 50 inch versions of the 3d TV but mine being a 50 inch version would the 55 mainboard work? Part numbers are the same.Did I leave the soldering iron on?
Main concern with putting 3D board in 2D is often 3D is brighter than 2D and sustains faster - this may mean the current sustains or power supply will struggle. 55" main board in 50" should be OK -- may have to tweak some of the settings to get ideal picture.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
