TV turns on and screen glows, has audio but no picture.
Saw there was some common failures with this model. But I don't see any obvious problems, Vs and Va both are good (207/63).
Glass fuses are good on PS, Ymain, and Xmain.
Had a similar model before Tom you helped it was a bulged cap and open through hole fuse by arrow in last pic (these are good), but everything else "looks" good here, not sure what to check now, this is only the 2nd plasma I've worked on.
May help to add that owner said it "Slowly" died, over the last couple months, if you kept turning on and off that eventually would get video and then a few days ago that ended...
