Visitor Messages
  • trean27
    • Aug 2014
    • 10
    • sweden
    hi, you seems to be the pro here
    I wonder if i could bother you about a little problem or a big one....
    I seen that you have good experience in older theads, and have some simular problem, with a Samsung Le46m51,
    i kind of know its the power board on my tv le46m51 that is the problem, have no picture, and power board hot side on the top picture, shows 100 volt not 160..
    and on the ribboncable over to the logicboard, its som high reading on the 13 volt connector (the only one) on top side. it shows 15.6 volt ,
    and 5 volts shows 6,45. the 12 volt is correct.
    so on the main board (logic) its some offset on reading to,
    from left ot right it shows.
    0, 3.26, 6.45 on first sekond 0, 1.79, 3.24 thrid 0, 5, 7,93. forth 15,57, 0 , 8volts. so that means there is on the right side on the ribbon cable that goes to the t-xon card is 0 output.
    so checks som electro caps on power board, but wonder if the 100 volts reading could be a problem on trafo, any ideas ?
    best regards niklas.
widgetinstance 457 (Related Topics) skipped due to lack of content & hide_module_if_empty option.
