Quadro LED-40TN42S2T2HEVC
  • Guerilla3
    • Aug 2021
    • 18
    • Croatia
    Hello.
    PS Vestel 17IPS62
    MB Vestel 17MB140
    TV died while in standby mode. Doesn't react to remote, or onboard on button in any way. No backlight. Standby light is off. Transformer buzzes silently.
    Quick visual inspection; no burn marks, caps look ok.
    Multimeter check unpowered; fuses are ok, electrolitic caps near or at rated capacitance, diodes ok.
    Multimeter cold side all boards disconnected from PS;
    mb connector 12v - 2.03v, stby - (-)2.96v, bkl and pwm 0v
    inverter connector 24v line is 6v
    all boards connected; 12v and 24v same as above, no easy access to other pins.
    Guessing the issue is the PS, but I have no idea what to look for next. Considering just buying a new board, but would like to confirm its the PS and find the exact problem if possible. Thanks.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Quadro LED-40TN42S2T2HEVC
    What is voltage across main capacitor?
    • Guerilla3
      • Aug 2021
      • 18
      • Croatia
      I am assuming you mean the 2 400v capacitors, they are ~315v.
      • Guerilla3
        • Aug 2021
        • 18
        • Croatia
        OK, on second measurement I'm getting 12.3v on 12v, and 35v for inverter now.
        • Guerilla3
          • Aug 2021
          • 18
          • Croatia
          0v for stby, bkl and pwm
          • Guerilla3
            • Aug 2021
            • 18
            • Croatia
            Now everything works. I'm guessing cold joints or something where the culprit, as I tested the voltages multiple times, with different board setups, and also I waited overnight to confirm the symptoms before opening it up. Now I will leave the tv disconnected overnight again, check if it works tomorrow and report back.
            • Guerilla3
              • Aug 2021
              • 18
              • Croatia
              TV works well today. At least I can confirm the problem was the PS.
              For future reference the working voltages when only the PS was plugged in without any other boards were: 35v for the Vled pins, some volts for the CH_1,2,3,4, 12v on 12v pins, and 0v for stby, bkl and pwm.
              Thanks dskall for replying.
              • dskall
                • Oct 2016
                • 2905
                • usa
                If you have problems again you will need to resolder things like the transformer and connectors.
                • Guerilla3
                  • Aug 2021
                  • 18
                  • Croatia
                  Will do, thanks again.
                  • Guerilla3
                    • Aug 2021
                    • 18
                    • Croatia
                    TV stopped working again. Tried reflowing most of the hot side, also transformers and electrolytic caps. DC voltages same as before for 12v and bkl. Main caps at 300+v.
                    • Guerilla3
                      • Aug 2021
                      • 18
                      • Croatia
                      Tried reflowing FETs, ICs and optocoupler.
                      Current situation is same as before; 12v line is 2v, and 35v line is 6v, both are lower by about 6x the needed voltage.
                      Main AC caps, and diodes before transformer are 300v+.
                        HP Z440 + Quadro K620 2GB i7-6700 Specification for Upgrade or Repair
                        This specification for the HP Z440 + Quadro K620 2GB can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z440 + Quadro K620 2GB boardview and Z440 + Quadro K620 2GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-12-2024, 03:30 PM
                        HP 240 MT + NVIDIA Quadro K620 i7-6700 Specification for Upgrade or Repair
                        This specification for the HP 240 MT + NVIDIA Quadro K620 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 240 MT + NVIDIA Quadro K620 boardview and 240 MT + NVIDIA Quadro K620 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        HP 440 MT + NVIDIA Quadro K2200 + Z24s E5-1620V3 Specification for Upgrade or Repair
                        This specification for the HP 440 MT + NVIDIA Quadro K2200 + Z24s can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 440 MT + NVIDIA Quadro K2200 + Z24s boardview and 440 MT + NVIDIA Quadro K2200 + Z24s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-12-2024, 03:28 PM
                        HP 230 MT + NVIDIA Quadro K2000 + Z24i E3-1226V3 Specification for Upgrade or Repair
                        This specification for the HP 230 MT + NVIDIA Quadro K2000 + Z24i can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 230 MT + NVIDIA Quadro K2000 + Z24i boardview and 230 MT + NVIDIA Quadro K2000 + Z24i schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        HP 440 MT + NVIDIA Quadro K2200 + Z27n E5-1620V3 Specification for Upgrade or Repair
                        This specification for the HP 440 MT + NVIDIA Quadro K2200 + Z27n can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 440 MT + NVIDIA Quadro K2200 + Z27n boardview and 440 MT + NVIDIA Quadro K2200 + Z27n schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
