LG 42PC1D (PDP42X30401) wiht flickering image and Vzb high
  • bo_vest
    • Apr 2021
    • 4
    • Spain
    Hello. I wonder if any of you guys may be able to point me in the right direction here.
    My 42PC1D (PDP42X30401) always had some red dots on black background. It never bothered me too much. One day it died (switched off)
    I replaced the Y-SUS board and it worked for a few days. After a few days I started getting grainy image when the set was cold. As soon as it warmed up it worked. The graining got worse and worse until it stopped working. Now I get flickering white dots. I can just about make out the menu on the screen so I know the TV as such is working because the menu comes up.
    Vs and Va are fine. On the Y-SUS board Vy and VSC jump a couple of volts but apart from that are correct.
    However, on the Z-SUS board the Vzb is supposed to be 100V DC but I can only adjust it down to about 130V DC. It is adjustable between 130V and 144V. What would cause Vzb do be high? Also, would a high Vzb cause the fault I am seeing?
    Boards are:
    YSUS
    6871QYH953A
    PD42066J030672
    ZSUS
    6871QZH956A
    PD42066K032558
    I attached pictures of the Y-SUS, Z-SUS boards and PSU. I also attach a zip file with a video showing the flickering image.
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: LG 42PC1D (PDP42X30401) wiht flickering image and Vzb high
    Hi!
    the photo of the power supply shows a lot of faulty capacitors that need to be replaced
    • bo_vest
      • Apr 2021
      • 4
      • Spain
      kasfamily, thank you for the reply. How do you know they are faulty? I am not saying they are not faulty. I am just asking how you can tell just by looking at them.
      Also, would faulty capacitors on the PSU cause the problem I am having?
      Finally, the input voltages on the Z-sus board are correct. I have only tested them with a DC multi meter so I cannot say if the DC is dirty. I could test that with an oscilloscope.
      • Questcom
        • Mar 2021
        • 12
        the tops of the capacitors are bulging, I can see at least 5
        Always learning - correct me if I'm wrong!!
        • kasfamily
          • Aug 2014
          • 774
          • Russia
          Swollen capacitors should be changed without thinking, and all the others should be checked ...
          • bo_vest
            • Apr 2021
            • 4
            • Spain
            Thank you for that useful feedback. I will change them and report back. Thanks guys
            • cjard
              Dell U27HM flickering/quarter image/black with smeared colors
              by cjard
              Hi all
              Wondering if I could get some insight on a Dell U27HM. First turned it on and the image was completely black. I later realised that if I dragged a window from one monitor to (the broken) other one then smeared colors would appear on the bottom 75% of the screen. After being on for several hours the top part of the screen started flickering showing an image (I have a video of this) and then suddenly the image appeared albeit rather fuzzy in the bottom 75% - image attached - and some hour later it now appears normal
              I do have two of these monitors so a compare/swap...
              09-13-2022, 07:12 AM
              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:20 PM
            • Jaime Morillo
              Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
              by Jaime Morillo
              Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
              The TV was stuck on the logo and I couldn't access the update menu.
              I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
              The image result was good, but the image is inverted.
              The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
              Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
              08-18-2025, 11:38 AM
            • TrueSword88
              KOGAN - KALED58RT9220SVA - Image flickering when in Energy Saving mode
              by TrueSword88
              Hi All
              I have a KOGAN 58' LCD Panel that 'flickers / pulsates' when in energy saving mode.
              I've reset the unit to factory default & rerun the initial setup but no change.
              IF I choose any other mode, example: Standard, flickering disappears.
              I've downloaded the most recent FW for this model from Kogan's website & re-flashed. This initiated a full wipe of the unit, which subsequently led to the setup all over again, however, the issue still remained - screen flickering but only when in 'energy saving' mode.
              I've taken the unit apart,...
              05-05-2023, 06:07 PM
              HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
              09-06-2024, 10:56 AM
