Re: Panasonic SA-HT820V Home Theater System
Nope, no way to tell
Didn't get -30 on TL1030.
TL1030 read 7.8 M Ohms
D1270 read 4.6 M OhmsLeave a comment:
Without -30 volts you won't get a display. To make sure there are no shorts on that line, CARFULLY remove the flat cable from P1102 and check if the negative -30v is on TL1030, if not, Unplug the unit and check the resistance of TL1030 to ground, it should be very high. Then as a last check, measure the transformer winding resistance It can be checked between D1270 cathode and ground (W56)Last edited by R_J; 03-16-2021, 07:40 PM.Leave a comment:
200ma 200v would be the minimum, that -30v supply is fairly low current, so any fast recovery diode greater than 200ma/200v would work.Leave a comment:
Oh ok, I was already searching for a Panasonic 200V 200mA diode since thats what the schematic said it was. So it doesn't matter?Leave a comment:
Just replace the diode, that should get the display back to normal. and then you can get back to the other problems. Any 1 amp 200v fast recovery diode will workLeave a comment:
It is likely shorted, You can unplug P1102 and check the diode again (don't damage the cable) just to be sure, or unsolder one end of the diode.
If the diode is shorted, that would explain the way the display looks. It is likely that when the flat cable twisted and partly came out of the socket it shorted the unregulated -30 to ground as the pins are side by side.Leave a comment:
If the diode is shorted, that would explain the way the display looks. It is likely that when the flat cable twisted and partly came out of the socket it shorted the unregulated -30 to ground as the pins are side by side.Last edited by R_J; 03-10-2021, 07:35 PM.Leave a comment:
Your problem seems to be that you are missing the Display -30 volts (UNREG_-30V) I suspect D1270 might be damaged. OR you have something on the unregulated -30v line that is shorted.
I suspect the the diode is burnt open or is shorted, and this is where the burnt smell came from.Leave a comment:
My post #5 i wrote its mechanic issue and need to put all at zero point.
yours display photo its tell same you have Order JAM ( because the lost of zero point and there are 2 or more micro switch sending order.) though this can damage the main IC. not C or R.
Here's the top and bottom. Do I need to take the trays out?Leave a comment:
I suspect the the diode is burnt open or is shorted, and this is where the burnt smell came from.Last edited by R_J; 03-10-2021, 06:01 PM.Leave a comment:
Ok so I was reading the schematic wrong because its a little different from my power board. I was reading it in the opposite direction. So it should read:
Pin 2: 31.8V
3: 6V
4: 6V
5: 16.5V
6: -.03V
11: 3.5V
12: 13.4V
TL1004: 3.5V
TL1006: 6V
TL1009: 13.4V
TL1016: 16.4V
TL1030: -.33V
TL1038: 31.6V
Fuse read good.Leave a comment:
Samsung Blu-ray Home Theater Set HT-F9750W Service Manual...
Channel: Schematics and Boardviews
10-14-2024, 04:16 AM -
This specification for the MEDION AKOYA P15645 + MS Office Home&Student 2019 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P15645 + MS Office Home&Student 2019 boardview and P15645 + MS Office Home&Student 2019 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-06-2024, 05:00 PM
This specification for the ASUS VivoBook S406UA-BM013T + MS Office Home & Student 2019 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S406UA-BM013T + MS Office Home & Student 2019 boardview and S406UA-BM013T + MS Office Home & Student 2019 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the...09-06-2024, 03:21 PM
This specification for the ASUS VivoBook S330UA-EY033T + MS Office Home & Student 2019 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S330UA-EY033T + MS Office Home & Student 2019 boardview and S330UA-EY033T + MS Office Home & Student 2019 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the...09-06-2024, 03:21 PM
This specification for the ASUS ZenBook UX3410UF-GV180T + MS Office Home & Student 2019 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX3410UF-GV180T + MS Office Home & Student 2019 boardview and UX3410UF-GV180T + MS Office Home & Student 2019 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...09-06-2024, 03:21 PM
- Loading...
