LG OLED 65EG9600 no picture
  • Diah
    replied
    Re: LG OLED 65EG9600 no picture
    to tell you the truth i am confused with this set.. i never faced LG in way its model OLED 65EG9600 had mainboards absolute different from other. mysterious
    micro led will be remarked with LD
    you wrote at first time you turn it on you got 1/2 screen distortion right side when you standing at front of the tv?
    you can disconnect the mainboards as you did before for test stand alone so this time you run the stand alone test but with disconnect the 2 ribbon cable of the 1/2 screen with distortion let see if the panel show any things- LOL
    i never did this crazy before... but maybe your TV crazy need crazy way too... or you just disconnect one ribbon no 2 from left
  • Daveleone
    replied
    Originally posted by Diah
    IN_STOP will need about 40 seconds not sure if you were giving to the set enough time for booting.
    Yes, it did take a while for the optical out LED to turn on. I waited some time after that. Still no picture.
    yours mainboards should have another 2 small red LED to turn on one for LVDS signal and other at the middle left side.
    I did not see any other LEDs near the LVDS cables or in the middle of the left side of the board. Can you point them out? I tried to take a better pic of the main board, I will attach it here.
    we can focus on the last things you did before 6 months
    I literally set the TV down in my garage, plugged it in, turned it on, saw the screen turn on with 1/2 screen distortion, watched it for ~30 seconds, turned it off, unplugged the TV.
    Then it sat there for 6 months.
    Then I picked it up, carried it into my house, set it down, turned it on...no picture.
    You should have 2 micro switch for reset... try pressing the one you have long press 10 second
    I only have SWI3000, my board does not have SWI3200.
    I held SWI3000 (I tried this in both IN_STOP and normal modes), heard relay click off, wait 10s, release SWI3000, set turns back on. No change (still no picture).
    contact the OP to have his mainboards and t-con
    Yes, let me know if you think we've done all we can to troubleshoot and if so, I will try to buy those boards from OP.
    Thanks again for your help!
  • Diah
    replied
    One things more i forget... on mainboard you should have 2 micro switch for reset.
    i can see only one and the other not in place... !!!!! so try pressing the one you have long press 10 second
  • Diah
    replied
    just to clarify some things you could didn't saw before LG OLED when we send INSTOP to it.
    the optical will not lit on direct after starting the TV on, the mainboards will need about 40 seconds until the first logo will come on screen, then first install so i m not sure if you were giving to the set enough time for booting.
    i cant imagine TV was working and after 6 months turning it on starting with this state
    if you remember what you did then we can focus on the last things you did before 6 months.. but if you told that it had picture and you didn't saw it self !!!!
    read my post #17 and contact the OP to have his mainboards and t-con. or all boards
  • Daveleone
    replied
    if you read all your posts starting from first one you stated 24V, and when it stand alone 24V too. and now as last test you write 22V.
    I think the difference is IN_STOP mode.
    When NOT in IN_STOP mode (initial testing):
    - get power, red light on optical out, sound (tv input static noise), and 24v on P203.
    - Also get 24v on P203 when in standalone (3-jumpered config - no main board connected).
    - Can get back to this state by issuing P_ONLY, exit, Power, and then turning the TV on.
    When in IN_STOP mode:
    - get power, red light on optical out, no sound, and 22v on P203.
    - Also get 22v on P203 when 24v cable is disconnected from T-con.
    - Also get 22v on P203 when DRV_ON jumpered to 3.5V (rest of signals on P201 cable are connected via the normal cable connections to main board).
    - NOTED, get 24v on P203 when in standalone (3-jumpered config - no main board connected, so IN_STOP mode not relevant here, but going back to non-jumpered config returns to 22v)
    put every things in place as original. dont send any instop or p only. just plug in wall and show me your mainboards to see howmany red led turning on
    Whether in IN_STOP mode or not in IN_STOP mode, there is only the 1 red light on the main board coming from the optical out.
  • Diah
    replied
    i am afraid you are doing some things wrong,, if you read all your posts starting from first one you stated 24V, and when it stand alone 24V too. and now as last test you write 22V.
  • Daveleone
    replied
    slide out the cable of DRV_ON which come from mainboards on the powerboards sockets P201 make ONE jumper Only between 3.5V and DRV_ON
    No change. Still no picture.
    DRV_ON = 3.5v
    P_ON = 3.3v
    P203 still reads 22v.
  • Diah
    replied
    Originally posted by Daveleone
    Just to make sure I'm doing this IN_STOP correctly
    if you send the command and tv go to standby with out the code 0413 little strange,,but could be yours service remote other version that do it with out code.. so you are in no need to give code..
    at this case when you send instop and its goes to STB plug it out from wall socket for 10 minutes then turn it on again.
    2) why do we get 24v when main board is not connected (panel+tcon test) but 22v when main board is connected?
    DRV_ON signal which mainboards send it to the powerboards content Freq which switched MOSFET of the 24V to high. if this freq low the output will be low. this is mainboards issue. and it could be too it didn't wake up the T-CON. so my previous statement about load are not in place.. regards to yours measurements.
    remember at yours first post you wrote that DRV_ON= 3.0V but when we do stand alone test after feeding DRV_ON 3.5V it turn to be 24V. this why we can now trick it in this way..
    after you send INSTOP, and plug the set out from wall socket and waiting time of 10 minutes then
    make ONE jumper Only between 3.5V and DRV_ON ( so the 24V will go high after you plug the set back to wall and turn it on with RC normal power incase it didn't start after plugging it back to wall
    your eyes always on the screen to remark any change
  • Daveleone
    replied
    one test you can do after you send the instop
    Just to make sure I'm doing this IN_STOP correctly...
    - I turn the TV on. Wait until I hear sound. Press IN_STOP, sounds stops, relay clicks, TV goes into standby.
    - If I start to press 0413, I hear relay click and the TV comes out of standby. Should I still do this? or skip this step?
    let see after you leave it over night off. next start tell if you have sign on screen.
    No change.
    plug out the 24V line from T-CON and turn it on
    No change (still nothing on the screen).
    NOTED that even though 24v is unplugged from T-Con, still showing 22v on P203. Is this expected?
    go back to run the test ( T-CON & panel as stand alone ) procedure
    (with 24v plugged in to T-Con, and TV in IN_STOP state)
    - Unplugged power
    - Unplugged P201 and set 3 jumpers
    - Plugged in power
    - Relay click
    - Nothing on screen. Noted that F1 now measures 24v.
    - Unplugged power
    - Removed jumpers and plugged back in P201
    - Plugged in power
    - Relay click, red light on optical port
    - Nothing on screen. Noted that F1 once again measures 22v.
    24V read as low 22V this tell us that the panel over loaded to drop the 24 to 22V
    If panel overload is pulling down 24v to 22v, then
    1) why do we still get 22v on P203 when not connected to T-con (& panel)?
    2) why do we get 24v when main board is not connected (panel+tcon test) but 22v when main board is connected? Maybe T-con is still not waking up in the panel+tcon test?
    Anything else to try?
  • Diah
    replied
    BTW you can contact the OP of this threat and take all his boards as they are working 100%
  • Diah
    replied
    dont use P ONLY any more. no sense for it while yours MB stating normal after plug it in wall socket.. also dont use normal Power on RC to turn it off in STB. keep it active at last state ( mean only plug it out from wall socket to let it at next start immediately when it plug in wall again )
    let see after you leave it over night off. next start tell if you have sign on screen. if nothings then you need INSTOP once again and dont do it any more... then ...
    one test you can do after you send the instop. just plug out the 24V line from T-CON and turn it on.... give attention to the screen if there horizontal line moved from the top to down.
    you can also
    after you did IN_STOP and turn it on you found the 24V read as low 22V this tell us that the panel over loaded to drop the 24 to 22V. this mean too the T-CON driver waked up. at this point if you plugged it out from wall. you go back to run the test ( T-CON & panel as stand alone ) procedure, you will have some things on the screen (maybe horizontal or vertical lines or full one color screen) this test now described to us why the 24V drooped to 22V or its could remain at 24V.
  • Daveleone
    replied
    as you own the LG SRC you can do both start with mouse and usb stick
    a)
    - Tried USB mouse and stick a few more times.
    - No change (still have power & sound, but no picture)
    - At least it did not go into protect mode this time.
    b)
    - With TV on & can hear TV input static sound...
    - Pressed IN_STOP
    - Immediately, sound stopped and heard relay click off and logo started flashing
    - Pressed 0413 just to be safe, but I think based on the relay click that the TV was already going into standby (?)
    - Logo continued flashing a few times, then shut off.
    - Unplugged TV.
    - Waited 10 minutes.
    - Plugged in TV.
    - Heard relay click. Got light on optical port, but no sound (maybe the input changed?) and no picture.
    - Tried powering off / on a few times. No change.
    - NOTED that we have 12v at F3, but only 22v at F1 (and at P203).
    - Pressed POWER_ONLY
    - Exit, Power
    - Powered back on.
    - Back to initial state (power and sound, no picture)
    - NOTED that we once again have 12v at F3, and 24v at F1 (and at P203).
    I tried the IN_STOP procedure a 2nd time, just to make sure I did it right. Same results.
  • Diah
    replied
    Yeah, I figured it was in protection mode and that's why P_ONLY worked. But I don't understand why it went into protection mode?
    Ok, I will try USB mouse & stick again first. Then IN_STOP 0413. And will report back.
    who knows what are you doing....lol
    oled protection happened when there are wrong firmware timing steps sequences between Main FW and T-CON FW or there HW caused this issue.
  • Daveleone
    replied
    i explained the protection mode at other threat when P ONLY need
  • Diah
    replied
    - Used service remote POWER_ONLY.
    - Pressed Exit, then Power.
    - TV shut off.
    - Pressed power button on TV.
    - TV turned on.
    - Successfully back to original state (have power, sound, optical port light, etc, but still no picture)! Whew!
    What does that mean that the TV wouldn't power on, but using POWER_ONLY then exit fixed it?
    What next? Should I try the mouse & USB stick again? Or not risk it and try IN_STOP 0413 instead?
    Thanks!
    i explained the protection mode at other threat when P ONLY need.
  • Daveleone
    replied
    remove the mouse and usb stick. keep it out from wall socket 10 minutes and more then plug it in wall tell the result.
    - Removed mouse & USB stick.
    - Left TV unplugged for 10 minutes.
    - Plugged in TV.
    - No change (still no relay click. power button on TV does nothing. power button on remote causes flashing logo).
    - Unplugged TV
    - Unplugged LVDS & P201
    - Re-jumpered. P201.
    - Plugged in TV.
    - Got relay click and 12v & 24v in the right places.
    - Unplugged TV.
    - Removed jumpers
    - Plugged LVDS & P201 back in
    - Plugged in TV.
    - No change (still no power. power button on TV does nothing. power button on remote causes flashing logo).
    - TV shut off.
    - TV turned on.
    Thanks!
  • Diah
    replied
    plug it in wall and tell what led indicator on mainboards u have on
  • Daveleone
    replied
    you may have one LVDS cable not correct sitting after you did or sockets... look over all again
    Ok, I double-checked them all. All seem seated properly.
    I also tested continuity between the 3.5V, P_ON, DRV_ON, and 12VT_ON pins on main board to corresponding pins on power board to make sure I didn't screw something up there and continuity tests ok.
  • Diah
    replied
  • Daveleone
    replied
    which sound you are hearing ????
    - I still heard the TV static sound the first time I turned it on. But not anymore.
    - Ok, I removed USB stick & mouse. Will leave unplugged for 10 minutes and then plug in power and let you know what happens.
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
    ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
    This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
    09-07-2024, 04:30 AM
    Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
    This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 07:12 AM
    Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
    This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
    This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 06:40 AM
