Samsung un50ru7100 2x5 blinks
  • itelite
    • Aug 2016
    • 124
    Samsung un50ru7100 - 2019 model.
    Intermittently it will fail to power on out of standby. It will blink double blink 5 times, pause, repeat this pattern, pause, then return to standby mode.
    It will often run for several days normally. (on for hours, turn off, turn on the next day, etc). Then some days without explanation it will do this blinking pattern.
    I know it is trying to tell me something with the blink code, but i cant seem to find the blink codes for this model.
    Anyone able to help me out?
  • Diah
    • Feb 2013
    • 6613
    Re: Samsung un50ru7100 2x5 blinks
    there is no blink code... what you facing now the eeprom of the main boards trying start its script and it continue start the script again.. until it give up ( failed ) it goes to STB
    when yours set start normal ... ( you can freez the eeprom to force it starting too ) log in service menu.. to make the hard reset.. this will initial the eeprom & nand. also if there update for this model do it.
    • itelite
      • Aug 2016
      • 124
      Ah so the EMMC flash is current then? Ok i will do as you said. i have ample time to work in the service menu since it works normally about 80% of them time.
      Firmware is current.
        09-07-2024, 05:50 AM
      • Nairolf
        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
        by Nairolf
        I have a Samsung DM32D display.
        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
        Here’s what I have tried so far:
        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
        From these tests, I suspect the problem might be on the mainboard. Could anyone...
        08-24-2025, 03:47 AM
      • howardc64
        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
        by howardc64
        • Prior owner tried a replacement main board. No difference.
        • Samsung 2x red blinking standby LED = panel fault
        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
        07-19-2025, 10:54 PM
        09-06-2024, 11:40 PM
