Crazy Samsung nu7020
  • layad
    • Nov 2011
    • 249
    Hi there, nu7020 , the led blinks all the time without stop, the power supply outputs voltages are not stable, jumps from 0v to the normal output, for example if one of the output should be 12v it jumps from 0v to 12v all the time, i thought its power supply problem but its not , if i remove the fuse which is before b13v_pw the voltages becomes normal, so its after this fuse, removed the fuse and injected 12v to check ifcany component heat up but nothing heats up, the amp is almost nothing, but the voltage on tge external power supply keeps drooping, even i dont know now if b13v_pw is shorted or not!! Q18 the other side of tgeckegs are shorted to ground, pls any one has tge schematics for this board? Or at least similar one to figure out how this board works? Thanks
    09-07-2024, 05:50 AM
  • jesterace
    Samsung UE46ES8000 Blown fuse but no other signs of short
    by jesterace
    Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
    09-11-2024, 03:14 PM
    09-06-2024, 11:40 PM
    09-06-2024, 08:40 PM
