Sony KD49X8005C Assistance Required Please.
  • Stevie406
    replied
    Re: Sony KD49X8005C Assistance Required Please.
    Originally posted by Diah
    be aware always. LED testing with just they turn on not enough. as each led had build in diode opposite to the LED light to limited the current. so led turn on but the diode shorted or some time open too
    Thank you, I will add this information to my notebook for the future.
  • Stevie406
    replied
    put your volt on meter on the LED socket and read the up and down when you power the tv on
    I Test the LED+ from the socket with plug disconnected, at power up 93.44v
    And LED- 0.23v
    I'm not sure I have taken the correct measurements you wanted.
  • Diah
    replied
  • Diah
    replied
  • Stevie406
    replied
    BINGO this is the error ... you have shorted LED diode
    Ok I will test the LED diodes to see where short is. Thank you.
  • Diah
    replied
    Originally posted by Stevie406
    I have just checked to see if the BL flash when first powered on.
    Only the top row of LEDs flashed at power up.
  • Stevie406
    replied
    before you put back the screen , u can turn on the tv with out screen but t-con should connect to MB BL socket connected .. turn on and tell if you can see BL blink once
  • Stevie406
    replied
    ok, I'll strip it back now. Thanks
  • Diah
    replied
    Sorry, I was looking up about the firmware and got carried away trying to update it.
    Should I power down the set, to allow me to get the voltages from the LEDs?
    It still looks like it is reading from the USB drive, That's been six and a half hours it's been running?
    this not read from usb. you have error so boot loader turn off psu
    its sync of usb input ... so back to post 25
  • Stevie406
    replied
  • Diah
    replied
    we was waiting on your feedback my question post 25 .. your volt reading was content BL err.
  • Stevie406
    replied
    I started a firmware update at 2:00, and I could see the USB drive read activity, It is still reading from the USB read activity.
    Is this normal for it to still be running for this length of time?
  • Stevie406
    replied
    also please check yout MB the LAN Socket. its look at your photo there are burn or dirt.
    The LAN Socket was only a little bit of fluff. All cleaned now.
  • Diah
    replied
    Typical, I have rebuilt the screen. I will dismantle again...
    I should have waited for more instructions first...
    Another lesson learned Sorry.
    tv can work normal with out screen.. please check result i asked you about the LAN Socket
  • Stevie406
    replied
  • Diah
    replied
  • Diah
    replied
    Checked the BL and all light up as expected.
    How would I go about reprogramming this set.
  • Stevie406
    replied
  • Stevie406
    replied
    in this 15 second was the screen blank and no BL as budwich write LED tester not enough. we have here bricked Android Sony TV, there are Hard Brick and soft Brick MB.
    TAKE THE Panel apart and check your LED BL.... if they are fine as yours statement before then you have Hard Brick.MB need reprogramming
    I will strip it back to the led strips and test properly, and report back. Thanks
  • Stevie406
    replied
    Originally posted by budwich
    it would appear that the bl-er is set so that will likely shut down the system. A tester doesn't provide the "full story" although it does give you a chance to test the entire string... but the system monitors the operating current and if that is out range... which the tester can't really check, then the system will error.
    what is the history of the set?
    Unfortunately, I don't know any history regarding the 3 sets I have purchased.
    I got them from an auction with the sole purpose of trying to further my knowledge in electronics repairs.
    Sorry, I can't help with any background info.
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • dkneyle
    Sony KDL-46HX850 Can't upgrade/update firmware
    by dkneyle
    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
    09-25-2024, 10:44 PM
    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-06-2024, 05:27 AM
    Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
    This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
    09-06-2024, 05:30 AM
    Sony VAIO SVT14126CX Notebook T Specification for Upgrade or Repair
    This specification for the Sony VAIO SVT14126CX Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT14126CX boardview and SVT14126CX schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony...
