Sony KD49X8005C Assistance Required Please.
  • Diah
    replied
    Re: Sony KD49X8005C Assistance Required Please.
    Originally posted by Stevie406
    LED+ 93.4v - 95.3v
    LED- 13.8v - 15.3v
    yours Luck i got today Sony 49XD series Android, P.SU same to yours. it had bad signal.. i order for it Tuner Board.
    i compared it for you, so you can use it as references with this set
    1- LED BL in STB are same you have, when TV turn on they GO High 158V then down to 107v - on chassis and + on the LED socket + , of course the 107V it depend on the setting of BL it may more or less
    2- as those Sony doesn't have power switch, also when it plugged at wall socket the White LED start on while the android starting. and it goes to last state. mean if the TV was in STB and took out from wall socket. it will start the android and then goes to STB state where the white LED will be remain OFF. BL Sockets read as yours.
    from this points if there are no any fault with LED BL or sockets. then just replace the MB.
  • Stevie406
    replied
    Originally posted by zomi
    All the wire connectors solder these direct
    either new wire or just snip the plugs off and solder
    i have circled them for you
    Ok. 10 Minutes and it will be done.
    Thank you..
  • zomi
    replied
  • Diah
    replied
    Originally posted by Diah
    i am off.. i don't believe on yours DM . if you have the easy one of diode test option with beep tone you had found the fault led..
    TV LED BL test should be as following
    when the DM on Diode mode when you put the probe and the LED light on, the DM as my will read nothings. then reserve the probe the DM will read value as ziner Diode between .650 -.756
    if the DM peep ton or read less than .500 mean this ziner shorted , if the DM no peep or no value read it mean its OPEN. and both above state are fault which make this err.
  • Diah
    replied
    i am off.. i don't believe on yours DM . if you have the easy one of diode test option with beep tone you had found the fault led.. please other help.. i keep my eyes on this post
  • Stevie406
    replied
    however. please inspect and re solder all joint point of string and socket.. dpnt left any with out resold them
    Ok, I will re-solder all connections, and re-test again Tomorrow, I'm getting pretty tired, and I don't want to make a mistake.
    Thank you for your patience, and assistance, I really appreciate everyone's help.
  • Diah
    replied
    I have tested ALL LEDs on ALL the strings, and the test results are almost the same.
    There is only 0.01v of a difference between ALL the LEDs.
    Just for future reference, Were you expecting to see at least one of the LEDs with a different reading from all the others?
  • Stevie406
    replied
  • Diah
    replied
    The first picture is with the Black probe on the negative rail and the Red probe on the first test point after the first LED.
    With the meter on Diode mode, I get a reading of 2.515v.
    This LED lights up.
    When I reverse the leads, the meter shows OL
    The 3rd picture shows testing the second and all other LED on this string.#
    I place the Black lead on the test point before the LED and the Red probe on the test point after the LED.
    The meter shows 2.525v
    This LED lights up.
    When I reverse the leads the meter shows OL.
    All LEDs are about the same value.
    I'm so sorry if I have misunderstood your instructions.
    this test you mentioned above only on the string which flash on at start up right ?
    if yes do the same to all other string led
    if not the one string we talk on which it flash once at start up wrote here its not
  • Stevie406
    replied
    This LED lights up.
    This LED lights up.
  • Stevie406
    replied
    ????? test as diode not volts.... tv must be off .. show me how you test with yours DM
    I will take some pictures of how I am testing LEDs. And upload in a few minutes.
    Sorry if I am doing this wrong.
  • Diah
    replied
    any one from English speaker counties please help him to test which LED fault.
  • Diah
    replied
    I have tested all of the LEDs with the meter in diode mode.
    All LEDs test from 2.53v to 2.51v.
    All LEDs have OL with leads reversed.
  • Stevie406
    replied
  • Diah
    replied
    no... you have one raw flash on... lol... how it come 1.6.....start testing put your voltmeter on Diode Option. and start test diode LED you can make references from reading value of working one each test should be in tow opposite direction of - +
  • Stevie406
    replied
    I'm getting 1.6v to 0.14v
    Is this correct?
    I tested a few times with similar results.
    The 1.6v is just for a fraction of a second, then it settles down to 0.14v
  • Diah
    replied
    why you put the - on chassis ? leave the - on - and + on +
    just read direct from the socket
  • Stevie406
    replied
    LED+ 93.4v - 95.3v
    LED- 13.8v - 15.3v
  • Stevie406
    replied
    again wrong.. from now on never never disconnected the LED socket from PSU. until you see all strips turn on when tv power on...
    also read the value again
    Ok . Another note for my book. Thanks
  • Diah
    replied
    I Test the LED+ from the socket with plug disconnected, at power up 93.44v
    And LED- 0.23v
    I'm not sure I have taken the correct measurements you wanted.
    also read the value again on the socket you have only 2 pin - and + this you need to read
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • dkneyle
    Sony KDL-46HX850 Can't upgrade/update firmware
    by dkneyle
    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
    09-25-2024, 10:44 PM
    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-06-2024, 05:27 AM
    Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
    This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
    09-06-2024, 05:30 AM
    Sony VAIO VPCEA3S1E/V Specification for Upgrade or Repair
    This specification for the Sony VAIO VPCEA3S1E/V can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VPCEA3S1E/V boardview and VPCEA3S1E/V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
