Need help testing an OLED TV | LG 55EC9300
  • Diah
    replied
    to make the set run again .. you need to cool the left side of the module where are there black,,, there are side COF .. spray it with cool spray it will turn fine for swhile
  • Diah
    replied
    as your uploaded photo of service menu InSTART... go to to option 13 OLED let see whats there
  • pearswick
    replied
    Apologies for the double post - I ordered a service remote, which arrived today, and it enabled me to turn the TV on and it (so far) seems to work fine.
    Would this imply my issue is indeed a power supply issue, and not (as I feared) a broken panel? I also bought myself a multimeter and plan to check the voltages across all boards. Or am I being too optimistic?
    Edit: the TV turned itself off again after about 45 minutes of perfect picture. When I turned it on again I had that half panel issue. See additional photos. Click image for larger version
    Click image for larger version  Name:	IMG_2783.jpg Views:	0 Size:	2.21 MB ID:	3175652
  • pearswick
    replied
    Ah that’s a shame - thanks - so you both reckon not worth trying to fix?
  • speter
    replied
    I tried another tcon, and it had the same issue, 😕 I finally gave up, and chucked it.
  • MASTER_TECH_101
    replied
    Disconnect LVDS cables between Tcon and Main, TV should turn on and stay on with all voltages present.
    LG OLEDs usually have bad panel. All suggestions above are pretty much vastest of time. You can't replace Tcon since it is married to panel itself and you will have terrible picture if any as well.
  • pearswick
    replied
    Was this issue ever resolved? I have what I think might be the exact same issue
  • Diah
    replied
    Re: Need help testing an OLED TV | LG 55EC9300
    Originally posted by speter
    It went back to running for only a short time again, the new TCON is on it's way again.
    I decided to run the test again, and see if it will start running a long time again.
    I was able to get pics to show that getting to the drivers would be imposible without destroying the screen.
    put back your ORG. T-COn and try to refund the replacement one if you can.
    OLED Cells if they discharging your set will work as you faced before for 1 hours.
    to discharge the panel cells, disconnect the 4 Ribbon cable from T-CON side only then let the pins of the ribbon cable touching the tv chassis for enough period. this will help discharge whole the panel at short time.
  • speter
    replied
  • Diah
    replied
    BTW you can dimming the screen from picture setting, brightness & Contrast / Color so 1 hours working windows you have will increase so so you can work on yours PC with the server i mentioned above.
  • Diah
    replied
    In n earlier post (23) you said to remove the plates, I have seen pics of later sets that have those, my set is older, and does not have them. Same tv as before, sorry for the confusion,
    It made more sense in my head when I wrote it, and l could not edit later.
    I will post a pic when the new TCON comes in
    i see T-CON work for 1 hours then went to protection shutdown... and at service menu you found inv fault for pixel refresh,
    i would suggest you start from now searching after LG Apache HTTP server for downgrade firmware.. and learn how you trick the LG to downgrade or rewrite firmware direct from PC.. reason some times if replacing T-CON the firmware of it didnt match the main FW on MB. so after downgrade both will match and will work fine after any upgrade of FW.
  • speter
    replied
  • Diah
    replied
    I was able to watch for an hour before it shut down again.
    How do I run the pixel refresh utility?
    The newer sets have a removable metal plate under the speakers to access the driver boards
    2 subjects at one post---- replacement t-con and other newer set..!!!!!!!!
    are you talking on yours OLD OLED or you have another one which work for 1 hours and turn off ??? its seem english not only for me difficult.. lol
    Photos always can replace thousands of letters...
  • speter
    replied
    I was not able to access the boards, I would have to dremel the back apart to get there. I ordered a TCON as a last ditch effort, the one I received was the wrong part. There is an additional white rectangle with a number in it, and I am not sure if it has to matc (4007j) it may be a software version?
    I let it run on self test for a while, and it started working with the old board.
    In the service menu, the reason for power down says inv fault.
  • Diah
    replied
    I think so... also.
    Thank you for sticking with me through this ordeal, I appreciate the help and knowledge you have given me!
    you welcome.
    try to access to the boards.. either if you with care cut the side edge of it,, you will not lost, some are clued with infrared Temp.at the edge of the cover
  • speter
    replied
    I think so... also.
  • Diah
    replied
    sorry ... this set rubbish
  • speter
    replied
    Unfortuneately on this set, there is no cover to remove,the edge board is completely hidden under the back, the back may be glued? on,(it may be destructive to try and open) as there is no screws holding it together, and only less than 1/4 inch thick. here is a pic of the final result of letting the panel stay on for 10 minutes, if I unplug and reset, it will rotate colors again,and stop on a random color like the screen pictured, once the screen was perfect for 30 seconds , but reverted to on side being dark again.
  • Diah
    replied
    There is no possibility Tcon is bad? , is there a way to know for certain?
    Yes I did the test exactly as you said.
    if you want to spend money to have replacement t-con always up to you.
    i wrote before encourage you to have access to the edge boards of the panel. its easy just remove speaker and metal cover... take look there who know you could find fortune at the effected side LOL. remember always with high resolution focused photos helped allot
  • speter
    replied
    this time the screen was green when it stopped changing colors, but the color bands go across the whole screen, I will get a pic next time
    ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
    This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
    09-07-2024, 04:30 AM
    Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
    This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 07:12 AM
    Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
    This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
    This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 06:40 AM
    Gigabyte AERO 14 OLED BMF-72EEBB4SO Notebook Specification for Upgrade or Repair
    This specification for the Gigabyte AERO 14 OLED BMF-72EEBB4SO Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72EEBB4SO boardview and 14 OLED BMF-72EEBB4SO schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 06:38 AM
