Samsung 932MW stuck on color test mode
  • mitsukiso
    • Sep 2017
    • 31
    • Италия
    Hi guys and thank you for sharing your experience
    probably somebody knows how to exit color test mode? some button combinations?.. just to try everything before working on eeprom.. thank you!
    09-07-2024, 05:50 AM
  • YellowJacket
    SHARP LC-32CHF5111K - stuck at color test mode
    by YellowJacket
    Hi friends,
    TV has stuck at - as I googled the term - color test mode. Slowly flashing colors white, red, green, blue, black, over and over again. I tried some hints from internet, like pressing some remote buttons, but nothing worked. I also tried factory reset for Sharp TVs => "while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan- " , but TV doesn't even start during buttons pressed.
    So I decided to flash new firmware to SPI ROM. What do you say, would it help? If so, where can I find some dump? I was unable to find...
    02-04-2023, 03:11 AM
  • signal.quest
    Samsung LN40C630K1F LCD TV No Backlights and Flashlight Test Fail
    by signal.quest
    I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
    I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...
    09-30-2024, 11:21 PM
    09-06-2024, 11:40 PM
