Samsung 50" Plasma Recap
  • kumasan
    • Dec 2014
    • 22
    • usa
    Have one of the Samsung 50" plasma, same model with the recalls for bad caps in power supply DYP-50W2, schematic same as in this post:
    https://www.badcaps.net/forum/showthread.php?t=32884
    I was having intermittent problem where the TV would randomly shut off and refuse to turn back on, just an initial click, and sometimes the TV would magically turn itself back on 10 minutes later.
    I recapped the main power supply, all caps except the big high voltage ones and the TV seemed to be better but shortly resumed the same or similar intermittent problem.
    Im now planning to replace the three remaining caps and touch up a couple solder joints that look a little age stressed. Would greatly appreciate any suggestions on what else I might check ps board or should I be looking at some of the daughter cards as well?
    There are a couple solder joints that look a little frosted from age with a very slight ringing. A couple on some fets and an opto isolator. They honestly dont look bad enough to be cold but I guess Im not an expert on what to look for.
    If I want to touch up some solder joints I wonder if I need to use a heat sink on the top side leads or should I be ok to quickly retouch the joint? Don't want to cook anything but it is also hard to get to some of the top side leads to apply the clip.
    Im not sure what is really happening when the set shuts off and then wakes up later with all the relay clicks. What happens when you press the power button, is there a microcontroller that waits for the signal and then enables/brings the rest of the system out of standby or is it a simpler standby circuit with a few discrete components that handle this?
    For the symtoms I describe are there any particular sections of the schematic to focus on?
    Appreciate any pointers/tips.
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Samsung 50" Plasma Recap
    No need for a heatsink. Use a 60w iron if you can and some 60/40 thin solder. I have seen the work of people who used PLUMBING solder, what a mess!
    • kumasan
      • Dec 2014
      • 22
      • usa
      My soldering unit is a HAKKO 836 (36w) so it is a little underpowered. I may have a handheld unit that has more wattage. For desoldering Im using one of the velleman cheap handheld units but the tip is a little too large for some jobs.
      Been meaning to pickup a better soldering iron for heavy applications and a desoldering unit. Any suggestions for decent quality/price units?
      Kuma
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        I use a 5-40 watt solder station made by Stahl. Works great for me.
        For de-soldering I use the blue Vellman and one from radio schack with the bulb built in.
        I used to use a Weller 40 watt iron, but the tips crapped out too fast. The Stahl seems to get hotter and the tip on it is 1.5mm and still the orig. one.
          09-07-2024, 05:50 AM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
          Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
          This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-06-2024, 06:20 PM
