Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Motherboard BN41-02156A ? BN94-xxxxx ?
      The first one BN41-02156A
        It is from your model (ue48h6670sz) that I don't have, I have many other dumps from this chassis and it is from BN41-02156A. You need?
          I could try with your version. Do you think it could work as well?
            Are you sure you have a problem in firmware 25Q40? You can try with my dump, just don't forget to keep your native dump!
              I'm pretty sure it's a firmware issue. I only have ch341 programmer so i'm not able to flash the nand chip. I hope for the best or i will buy new tv. My readings into chip are most FF and some others unsignificant values. Any ideas for tv stuck on boot logo?
                In this chassis, flashing eeprom (24C256) often helps from freezing on the "Smart TV" log, if it does not help, then flashing the entire set (eMMC, Spi flash and Eeprom).
                  Just in case, please do you have also the eeprom file? My eeprom is labeled IC901 part number s24c51. Thank you
                    Do anyone has it please?
                      Who, exactly what?
                        Does anyone have a dump For Vizio m60 d1 please
                          I have a Samsung un55ku6290f that turns on as soon as I plug it up. There is backlight but that's it. No image or remote control functions at all. Could this be a bad bios.
                            Hi guys I'm looking for a firmware for a Samsung tv, model UE55J6200AWXXH
                            Board code BN41-02353B
                            Model : BN41-02353
                            Thank you
                              Insignia NS-50L260A13
                              Here is a working spi flash for Insignia ns-50L260A13
                                I need flash dump for Sharp LC-60LE740E mainboard DKEYDF733FM65, QPWBXF733WJN2
                                  Dump what eeprom, nand...? Post your non-working dump here.
                                    The nand I need (IC8401), i thought mentioning flash would be enough.
                                    The non working one is not relevant, the guy from whom the set is, upgraded the TV from USB stick for a different main board (LC-60LE745U) so now the lvds isn't working.
                                      Link to dupm nand in private messages, try it.
                                        Thank You lotas!
                                          I need working bin for HAIER LE32F6500 TV (TP.VST59S.PB813).
                                          Attached is my dump bin file. thanks
