Grundig Xentia 82 (MFW 82-490) (CUC 1931) - intermittent blue Blue
  • sausagejohnson
    • Dec 2016
    • 20
    Hi Guys,
    First post. I have been trying to fix this Grundig Xentia 82 CRT TV for some time with mixed success. The schematics for this TV and it's various boards is available here:
    Problem:
    The blue information from the TV signal and video inputs is missing intermittently. Red and Green are rock solid.
    Points to note:
    • The blue from the setup menu is still present which rules out a problem with the blue gun. Possibly also rules out a problem with the CRT Panel.
    Boards in the TV:
    • Main / Chassis Board (like a motherboard)
    • Socket Board (contain SVHS socket)
    • Processing Board contains VGA Socket and several chips:
      C161RI 16-Bit Microcontroller
      M27C160 "EPG-PLATTE" EPROM
      UM61256 15 Watt DC-DC Converter,
      MC74HC4094 8bit Shift Register/Latch
      M24C16 serial I2C bus EEPROM
      "TEXT" 68-PIN PLCC chip
      TDA8601 IC RGB Fast Blanking 16DIL
      Other misc chips, ram, latches.
    • Feature Box Board, which contains chips like:
      SDA9362 DDC-PLUS-deflection controller
      SDA9400 Scan Rate Converter
      SDA9280 Display Processor
    • Signal Module, contains:
      Tuner,
      VIF/TUNER AGC
    • CRT Panel
    • AF Module
    • Other small misc boards
    Action taken to resolve, and results:
    1) Opened and removed boards, vacuumed, reassembled.
    Result: Blue returns but disappears after a few hours.
    2) Checked as many Electrolytic capacitors with a ESR meter from the boards and main board as I could reach, and the values seemed to be in range. I couldn't get to them all. Reassembled.
    3) Searched the schematics for blue lines, but most appear to be along surface mount components. There was a blue line on the Processing Board, but the Electrolytic capacitors on the board didn't appear related. I re-soldered the capacitor joints in case of dry joins. There was a Film capacitor on the Processing Board that was on a blue line, and I replaced that as I had one handy.
    Result: The blue became solid again for around 2 weeks. Then occasionally it would drop out. A few days later, is was half and half, and now the blue only shows for a few seconds every hour.
    What help do I need?:
    1) I would like to know if the behaviour of the TV with the intermittent blue, does it seem like the work of a faulting Electrolytic capacitor? Or would it seem more like the behaviour of dry joints?
    2) Could someone please explain what the Processing Board, Feature Box and the Signal Module boards do? I spent most of my time trying to work on the Processing Board, and it seemed to bring back the blue for the longest period. Was this a co-incidence? Am I working in the right area for the blue signal from TV and inputs?
    If anyone could provide any guidance I would be very grateful, as I love this TV and it is way too good to replace just yet.
  • sausagejohnson
    • Dec 2016
    • 20
    Re: Grundig Xentia 82 (MFW 82-490) (CUC 1931) - intermittent blue Blue
    I'm happy to close off this thread as I managed to resolve the issue myself in the end.
    As described in the symptoms above, things would be good for a while after opening and attempting to service. So the act of something moving around would help temporarily.
    Later I noticed in the hotter months, the colour failed less often. Cooler days the colour would fail more. Got me thinking about metal expansion making better contact.
    In the end, I resolved it by re-soldering the largest solder contact points on the motherboard where the card sockets attached. In some cases I removed most solder before applying fresh stuff.
    Long story short, I nailed it. The colour has been rock solid for about three weeks and everyone at home is happy again.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Thanks for sharing resolution to your problem. Helps us all to know what fixed the problem.
        Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
        This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
        09-07-2024, 05:50 AM
        Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
        This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
        09-07-2024, 05:00 AM
        Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
        This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
        Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
        This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
        Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
        This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
