Samsung UE32D5720 permanent reboot
  • PontyPCs
    • May 2016
    • 16
    Re: Samsung UE32D5720 permanent reboot
    The Samsung D Series TVs Suffer From NAND Flash Failure, The Symptoms Are BOOT LOOP.
    Usually The Samsung Logo Appears Then Shuts Down And Restarts Continuously. You Can Check The NAND Flash By Using Freezer Spray On It, With The TV Off, Freeze The NAND Flash I'c Then Turn On The TV. The TV Should Start Normally. If This Is The Case, You Need To Replace The NAND Flash With A Pre Programmed One.
    I Have These In Stock £26.00 Plus P+P
    • Samsungx
      • Jun 2020
      • Netherlands
      Originally posted by mitzhamike
      1. Try resetting the eeprom (ic801) by shorting M_HRESET and M_E_SDA
      2. Reflash nand, ic1302.
      I have the bin file for d5500 or d5700.
      Could you maybe share the bin files with me? Thanks!
      • ldoctoru
        • Jul 2018
        • 9
        • romania
        hello can you share link for dump d5700
        • raileanu
          • Sep 2015
          • 127
          Please can anyone share the dump for nand BN41-01605A?
          • SsimoR
            • Apr 2020
            Could you please share the bins with me?
              09-07-2024, 05:50 AM
            • brkie
              Samsung UE75TU6905 reboot loop
              by brkie
              I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
              I read on Samsung's website (reviews)...
              09-04-2024, 01:45 AM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
