Samsung plasma TV never stop clicking pn50a510p3
  • hmendez86
    • Jun 2015
    • 344
    • united states
    I did research and shoppjimmy had a kit for main board I order it and install and still doing same thing.. what I think the problem here is the power supply...I check the sntby-5v and is ok....no vs, va nothing at all...I check from rectifier to transistor and they seem ok I have soome measure ackward numbers they have 5leg transistor ??don't know how test them...any clue???? Am pretty sure not the main board.....how can I test the power supply alone to be sure.....is working.
  • flocko
    • Nov 2012
    • 1121
    Re: Samsung plasma TV never stop clicking pn50a510p3
    Your power board will be the BN44-00222A ? And it shows a green LED flash code when faulty, you will find it screen printed on the bottom right corner at the side of the little board that stands up, check code and get back
    • hmendez86
      • Jun 2015
      • 344
      • united states
      Stock picture......same power supply I have....doesnt have the green ligth
      .I know what power board you saying.
      • flocko
        • Nov 2012
        • 1121
        Test the board by removing all plugs apart from mains in, you need to find PSon pin on white socket (bottom right) you say you have stby but check it again same socket? if thats Ok make PSon low (ground it to chassis ) that should bring the relays in,and give you all the low voltage outputs from the board, if this works then find Vs on pin and with a resistor (470-1000 ohm) make Vs on high (jump to 5v stby ) this should bring up the Vs voltage and complete the power supply test. report and let us know how it goes
        • hmendez86
          • Jun 2015
          • 344
          • united states
          So I jump( Ps_on to ground) and should power the relays???
          • flocko
            • Nov 2012
            • 1121
            Yes with mains supply from wall socket and all others unplugged if you have stby 5v and make PS on low. relays will come in,and all low voltages should come up
              09-07-2024, 05:50 AM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
              Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
              This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 06:20 PM
