Samsung PS-50P91FD Plasma repair help, sound and glow, no test pattern
  • Recyclojunk64
    • 6
    Hi, I'm trying to repair a 1080p Samsung plasma display, PS-50P91FD.
    It turns on and makes the startup sound, then primes the display with a flicker and continues glowing faintly. Sound input works. Makes 5 flashes of the red LED then stops flashing (off).
    Vs, Va and Vg are correct. Didn't test Vsc. All fuses I could find (glass and poly) were fine. No obvious damage.
    I shorted pins 3 and 4 on the four-pin square vertical header on the control board, and removed the LVDS cable from the control board. There was no test patterns, just the same glow as before.
    I read on another thread that it may have been pins 1 and 2 on certain control board models, so I tried shorting those two instead, just to be sure. Upon plugging it in, it acted as if it were completely dead. So I removed the jumper and replaced the LVDS cable.
    However, upon plugging it back in again, it was still completely dead, while the power supply continued to make it's usual hum/whine. All power supply voltages except PS_ON (2.6v) were missing, and the green LED power supply light was off.
    So now I suspect that the control board is damaged in some way (or perhaps bricked?) as the PS_ON signal goes only to the control board. Not sure though if the control board was the original source of the problem, or perhaps it was the X buffers/drivers. Would have been nice if I could have checked the for signals coming from it with my o-scope first though before now.
    So would it be worth ordering a new control board for $40? Or is it more likely that the original problem was in the X buffers and it's a lost cause?
    Thanks for any advice
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
  • LEECH666
    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
    by LEECH666
    Good day ladies and gentleman!
    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
    01-19-2024, 05:46 PM
  • SluggerB
    LG Plasma (PDP50R10101) No picture No sound
    by SluggerB
    This is my first Craigslist freebie fix attempt. 50 inch LG Plasma TV Previous owner said over time it was struggling to turn on, it would take 4-5 times to turn on, the one day it just did entirely. I took it home and plugged it in, I her a click, then a second later another click, and nothing. Dead as a doorknob
    So I took the back off and check voltages. The power supply appears fine, I checked the VS, VA, and 5V voltages and they all measured correct, on the power supply board and on the display boards (Y and X boards). All the fuses are fine
    Following a YouTube videos...
    12-03-2022, 09:10 PM
  • Christos Tsiligiannis
    Marian Trace Alpha sound card repair help
    by Christos Tsiligiannis
    Hello to the forum.
    My name is Christos, I am new to the forum here and i am posting from Greece.
    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
    So i tried asking for a schematic from the company and they would not give me one. Instead they...
    11-18-2024, 05:26 AM
    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
    This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-12-2024, 02:30 PM
