Panasonic TH-42PX50U Red light blinks 4 times
  • keico
    • Oct 2011
    • 52
    I have a Panasonic TH-42PX50U was playing fine then all of sudden no video and now the red light blinks 4 times
    Shut it off and the video comes back but after a few seconds the same thing
    Any suggestions
  • mecha1166
    XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
    by mecha1166
    I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
    07-01-2024, 05:47 PM
  • Andre Gilbert
    by Andre Gilbert
    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
    11-20-2024, 08:52 PM
  • Alicat
    Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
    by Alicat
    Stopped by this site trying to fix my parents Panasonic Plasma TV.
    Model number is TH-50PZ85U
    Power comes on and the red power light stays on solid.
    Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
    I also hear a few clicks.
    I also think my parents said there was a thunderstorm and the TV failed after that.
    Section 6 in the service manual talks about power and no screen,...
    10-30-2024, 10:09 AM
  • Nairolf
    Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
    by Nairolf
    I have a Samsung DM32D display.
    When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
    Here’s what I have tried so far:
    1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
    2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
    3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
    From these tests, I suspect the problem might be on the mainboard. Could anyone...
    08-24-2025, 03:47 AM
  • Samunggg
    Samsung UN70NU6900FXZA - Red Light Blinks 2 Times Then Screen Flickers
    by Samunggg
    I've happened upon this TV, it came with no power cord or remote and it seems to be experiencing a common issue where the red indicator light blinks 2 times then the screen flickers as if it's trying to turn on. No picture, no sound. I suspect the functions of the TV are in good order and that the underlying issue is with the power button which is missing. It's just a white tab where the button should be which means I can't cycle it.
    I wanted to know if there is anything I can do or if I should just get a replacement module with the hopes it will fix the system. Alternatively if...
    09-06-2023, 06:39 PM
