Hi there,
My Samsung LE37B550A5W suddenly started showing a distorted picture yesterday, I would really appreciate your thoughts on the problem.
Fault description: The picture went very dark and high contrast. The image seems slightly noisy and everything has a glowing white outline (see comparison) and there's an apparent horizontal ghosting (the horizontal lines follow the movement of program windows, the cursor, etc). The refresh rate seems to be down as well The fault is apparent across the menus and all input I could test (there's no cable attached, so I couldn't check that).
When I turn on the TV after leaving it standing for a while it starts up showing the issue, but gradually it gets even darker within less than a minute.
The display was used as my primary display for my desktop PC from 2009, so it has a lot of mileage.
Do you think it's a dried out capacitor, something on the T Con board or something different?
Thanks in advance!
Pictures attached below:
Thanks in advance!
Thank you so much Tom, you are ace!
