Sony klv32v400a red blink eight times
  • slay283
    • Aug 2014
    • 3
    • Brunei
    Hi, i have a this tv broken a few years ago and i am trying to fix it if its possible and easy to do it.
    When i turn it on it blinks eight times and i already plug off all the audio that plug in. So may i know what the problem is and how to fix it. Thank you.
  • Nairolf
    Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
    by Nairolf
    I have a Samsung DM32D display.
    When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
    Here’s what I have tried so far:
    1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
    2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
    3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
    From these tests, I suspect the problem might be on the mainboard. Could anyone...
    08-24-2025, 03:47 AM
  • Smartec82
    Sony KDL-55W802A - Red led blink 8 times
    by Smartec82
    I have this tv that works for about 15 to 20 minutes and then turns off, leaving the led to blink 8 times, this via HDMI, because I can't get into the tuning menu, it says Function unavailable.
    Through the manual, I was able to verify that it could be a software problem, but unfortunately the tv already has the latest software and that's why it won't let me update.
    Does anyone know of a way to reinstall the software?
    02-24-2023, 05:02 PM
  • matwan
    Sony XR-55X90J 5 blinks
    by matwan
    I have problem with SONY 55X90J. After several check status is as below;
    1. Running power board as stand alone:
    TCON_12V =~ 12.6V
    EVDD V On Max 24V= 19V.
    2.
    Running power board with TCON as stand alone:
    Effect as below, attched.
    3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
    "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
    Best regards....
    09-28-2025, 04:26 AM
  • GoodCapDude
    Sony XBR-75X940E intermittent 6 blinks error code
    by GoodCapDude
    Hi everyone. First post on Badcaps!
    I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
    09-20-2025, 06:07 AM
  • JarzabekPZ
    HP Victus 15-fb0104nw not turning on, charging led blinks 3 times
    by JarzabekPZ
    I'm working on a HP Victus that is not turning on. When power button pressed it only blinks 3 times with charging led. I have checked input mosfets and they are fine. Also all coils are fine too. Battery was empty but I charged it with my lab PSU and laptop started on batery but is not charging. When battery is disconected and only PSU connected it takes 0 current and not starting. What can be the reason?
    09-18-2025, 08:16 AM
