samsung ps51d6900 dead
  • stockers
    • Jul 2014
    • 11
    hi all
    i have a samsung ps51d6900 that seams dead.
    i tested the output of the psu and im not getting any vs or va output even tho the ps on signal is present.
    because of this, i bout a new psu. but iv got the same symptoms.
    the red light on the front flashed with presses of the button but iv got no green led on the small logic board.
    any ideas people???
    thanks in advance
  • Hamie
    • Apr 2014
    • 1383
    Re: samsung ps51d6900 dead
    Unplug the x and y sus.
    Does it turn on?
    • stockers
      • Jul 2014
      • 11
      if x and y sus are disconnected, there is 10.6v on va but 0 on vs. if just x sus is unplugged, i get the same 10.6 and 0v
      • Hamie
        • Apr 2014
        • 1383
        Is the power supply bn44-00446A?
        • stockers
          • Jul 2014
          • 11
          yes, thats the one
          • Hamie
            • Apr 2014
            • 1383
            Ok put a jumper between ps-on and gnd.
            And vs-on and stby
            • stockers
              • Jul 2014
              • 11
              ok, did that and got vs and va voltage as it should be. connect y sus, fine. connect x sus, clicks on and of a few times then shuts down
              • Hamie
                • Apr 2014
                • 1383
                Have you soldered the jumpers or just used wires in the plugs?
                Ie is the main board still connected?
                • stockers
                  • Jul 2014
                  • 11
                  i used bits of wire
                  • stockers
                    • Jul 2014
                    • 11
                    no, the main board was disconnected
                    • Hamie
                      • Apr 2014
                      • 1383
                      Do you see a service vs test point on the y-sus.
                      What's the reading?
                      • stockers
                        • Jul 2014
                        • 11
                        that reads 207v which is same as on the label for the panel
                        • Hamie
                          • Apr 2014
                          • 1383
                          Finally check the vsc and -vy voltages.
                          Voltages for these should be on the sticker, 190v -190v roughly.
                          You should also have sound with the x-main disconnected.
                          If you do, y and buffer are probably good, replace the x.
                          • stockers
                            • Jul 2014
                            • 11
                            all voltages good. why would the led on the main board not be lighting up? does the dead x sus cause this? would it also cause there to be no vs or va voltage even when its disconnected (and no jumpers) ???
                            • stockers
                              • Jul 2014
                              • 11
                              i am indeed getting sound...
                              • Hamie
                                • Apr 2014
                                • 1383
                                The led should blink like a heart beat. Once every couple of seconds.
                                If it doesn't i.e. is permanently on or blinks really slowly or really fast usually indicates a fault.
                                Hopefully though by replacing the x the problem is solved.
                                Also when you replace the x, if all is good and the tv is working, check to see if there is a firmware update from samsung and update the tv via USB.
                                • stockers
                                  • Jul 2014
                                  • 11
                                  there is nothing from the led. does not blink at all. would it be worth replacing the main board aswell?
                                  • Hamie
                                    • Apr 2014
                                    • 1383
                                    Id just replace the x. Doubt there is any other problem.
                                    • Heerh
                                      • Jul 2015
                                      Hi Hamie,
                                      I have the same TV model and the it doesn't start and there is no sound as well. the standby light blinks 6 times then nothing happen.
                                      I opened the back plate and I can hear a buzzy noise ( its not very loud), I think the noise comes from the small white transformer on the power supply board. I'm not sure if that's causing the problem or there is something else. I was looking for a new transformer but I cant find it any where! any advise please?
                                      Thank you
                                        09-07-2024, 05:50 AM
                                        09-06-2024, 11:40 PM
                                        09-06-2024, 08:40 PM
                                        Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                        This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-06-2024, 06:20 PM
