Plasma Z50PT320 Image Flickers and Goes Black
  • algares
    • Apr 2014
    • 10
    Zenith Plasma Z50PT320 Had no picture. replaced the Logic CTRL and I got picture for 2 minutes! Now it has picture and sound but pictures flickers after a while and goes black.
    I replaced the power supply, ysus, and top / bottom y scan drive with used parts from ebay.
    I checked voltages coming into power supply and it reads 124, fine I guess. Checked Va and Vs on power supply and it gives me 54 for Va and 204 for Vs. Label says Va 55V and Vs 205V.
    I also checked the voltage coming out of the Ysus to the Buffer boards. This reading goes all crazy with high numbers. Ranging from 400, 500, 600, etc. I replaced the battery on my multimeter just in case. The multimeter is set to VDC 600.
    I did all the test with my original parts and with the replacements and I get the same crazy readings.
    Please help
    Re: Plasma Z50PT320 Image Flickers and Goes Black
    Is there a chance you could record a video of this flickering so we could see exactly what it looks like?
    • algares
      • Apr 2014
      • 10
      There you go sir,
      http://youtu.be/A6w6tNJ74SY
      When I move back it basically stays black for a while. Sometimes the image will come back for a second and disappears again. While doing this I can hear changes in the sound coming out of the Ysus.
        OK, and so when it does this there is no change in the Vs/Va voltages?
        • algares
          • Apr 2014
          • 10
          Yes and at the same time I hear the sound from the ysus louder and the multimeter goes to 1 with a beep. Then back to the ranges of 400, 500, 600.
          • algares
            • Apr 2014
            • 10
            Bump
              Your meter is probably not internally shielded. Plasma TVs produce a lot of interference with the back cover off which could be causing problems for your meter. Any chance you can borrow a different one?
              • algares
                • Apr 2014
                • 10
                It's there a way to shield the multimeter? What about the tv not working. What could cause the image showing up for the first two minutes it's on, then it's black?
                  Not sure how you'd shield a multimeter. A problem with the -Vy/Vsc is most likely to cause an issue in my opinion.
                  • algares
                    • Apr 2014
                    • 10
                    Thanks a lot tom66 can you elaborate a bit on which ones are Vy and Vsc?
                      Aren't they the ones you are measuring - the ones going crazy?
                      • algares
                        • Apr 2014
                        • 10
                        Sorry I'm a complete newbie to the plasma scene. I know the name ysus and y buffers.
                          My fault, I was getting mixed up with another TV. On the top left hand edge of the plasma panel, or in the middle, there will be a sticker with "PDP50X4#######" or similar written on it, what is your "PDP" number?
                          • algares
                            • Apr 2014
                            • 10
                            Pdp50t30010
                            • algares
                              • Apr 2014
                              • 10
                              Tom66 why the PDP model? Thanks for your help. I'm about to put this one in the trash can!
                                Sorry missed your post. It's for this.
                                ...but unfortunately it doesn't have 50T3 alignments, so I'm going to have to work on a picture of the Y-sustain. Do you see any points marked "-Vy" or "Vsc" on the board?
                                  HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                  This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                  09-12-2024, 02:20 PM
                                • Jaime Morillo
                                  Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                  by Jaime Morillo
                                  Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                  The TV was stuck on the logo and I couldn't access the update menu.
                                  I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                  The image result was good, but the image is inverted.
                                  The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                  Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                  08-18-2025, 11:38 AM
                                • piershs
                                  Toshiba plasma 50WP16 wierd double image fault
                                  by piershs
                                  My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
                                  Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
                                  • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
                                  • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
                                  08-01-2020, 01:07 PM
                                • Delired73
                                  TV LG 50PA4500 Plasma : bad image noisy
                                  by Delired73
                                  I have an issue and didn't find any solution by myself or on every forum about my LG plasma TV 50PA4500.
                                  Originaly the TV stopped to work and didn't want to turn ON again.
                                  After visual inspection, few transistors were broken, I tried to change them but some burned again, so I ordered on full new board. So, I changed the Yboard which was burned by a new one
                                  It now turns ON and the image and sound are present. But the image is very noisy and only visible when the room is in the dark.
                                  I check Vs and Va voltages...
                                  04-04-2021, 09:13 AM
                                  HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                  This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                  09-06-2024, 10:56 AM
