Samsung hp-s5053, all 4 fuses are good, Im getting millivolts on the fuses closest to power connector on power supply. I know the power supply is faulty, I would like to trouble shoot the board. All caps LOOK good, should I be looking for cold solder joints?
Samsung HP-s5053 No Power,Standby light,NOThing
Re: Samsung HP-s5053 No Power,Standby light,NOThing
Check if any of the fuses are blown, using ohms range. (Power board unplugged!)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
All 4 fuses are 1 ohm or less. I have 5 of these power boards, all faulty. That why Im hoping to fix it,I have parts. LOLLast edited by topfli8979; 03-09-2014, 12:23 PM.
On these TVs you MUST have a cable plugged into the appropriate ports for the TV to allow you to select them.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I had a HP-S5053 with no stand by. When I measured the standby voltage it was very low and fluctuated between 1-1.5V. After doing some mind numbing analysis, tracked it down to a blown thermistor on the power board. Hopefully it helps someone here.
