LG 50PV450 no video
  • jb_gt_84
    Repair hobbyist
    • Dec 2013
    • 9
    LG 50PV450 no video
    Hello all,
    I have a LG 50PV450 Plasma TV that was given to me. The manu date is 11/2011.
    It has audio but no video. The Vs, Va and 5V from the SMPS look OK. On the Y-SUS board, the Vy- signal jumps to approx -190V then decays back to -25V at a 800ms duty cycle. So I figured the Y-SUS board was bad and replaced it. However, I still get the same results. I removed the Y-BUF boards and now see a steady signal on the Vy (-190V) and Vsc (150V) per the unit label. So are the Y-BUF boards bad? I'm thinking I should replace them as a set, correct? Thanks in advance for your help.
    Re: LG 50PV450 no video
    You can try isolating one board at a time.
    Usually with bad Y-buffers the voltage will be low immediately, I'm not sure if going low after some time indicates a fault or just a control board shutting down.
    • jb_gt_84
      Repair hobbyist
      • Dec 2013
      • 9
      So finally got y driver boards and installed them.
      I now have a picture! But it's not very good!
      Am I correct that the Z-SUS is bad based on the pixelation?
      The bottom half also looks like the y-driver is bad, but it's a new board as is the Y-SUS. Could the previous bad y-driver have damaged the Y-SUS or did I get a y-driver or Y-SUS that was no good?
      Thanks!
      • freakaftr8
        • Oct 2012
        • 3743
        Disconnect lower y buffer board and try with just upper in place.
        • jb_gt_84
          Repair hobbyist
          • Dec 2013
          • 9
          The lower y driver has a ribbon cable and 2 plugs that connect directly to the Y-SUS.
          I found a service training manual for this TV and it says not to operate the Y-SUS if the ribbon cable is removed, but the y-driver is plugged to the Y-SUS. If I remove the lower y driver, I don't have that ribbon connection to the upper y driver, so it seems this is something I should not try?
          • freakaftr8
            • Oct 2012
            • 3743
            Yea your right. Can only operate with lower y buffer in place. Sorry for that. Just tried with an lg set I have and it's all mal discharge if you do that since no data will be received to the buffer. Well it almost looks as if your lower buffer is acting up. Did you purchase these buffers from a cracked screen TV?
            • jb_gt_84
              Repair hobbyist
              • Dec 2013
              • 9
              The y driver boards came from ShopJimmy.
              They say they are new.
                On the back of the plasma panel module inside, there will be part number, like PDP52T8000, what is written on yours?
                • jb_gt_84
                  Repair hobbyist
                  • Dec 2013
                  • 9
                  Pdp50r30111
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    That's 720p. Listen closely. Any ticking coming from the ysus?
                    • jb_gt_84
                      Repair hobbyist
                      • Dec 2013
                      • 9
                      I hear a hum from both the Y-SUS and Z-SUS but not a ticking.
                      • jb_gt_84
                        Repair hobbyist
                        • Dec 2013
                        • 9
                        The label on the monitor shows 150 for Vsc but it's pegged at 144.5V
                        PS I have borrowed a scope for the weekend.
                        • jb_gt_84
                          Repair hobbyist
                          • Dec 2013
                          • 9
                          Looking at the signals on the 4 plug connectors between the y-sus and y drivers I see the following:
                          On the top expected 10.9VDC and saw 10.8VDC. On the other 3 connectors, I expected Vscan as 107VAC (~350Vp-p). On the middle 2 connectors, Vscan is a steady ~140VDC and only on the bottom connector do I see a waveform similar to that shown in the training manual. I removed the y drivers and saw the same signals.
                          So shouldn't I see the same Vscan on all 3 connectors? (Input was none - static on screen)
                          (y-sus is from paylesscomponents and was listed as new.)
                            HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                            This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                            09-12-2024, 02:00 PM
                          • PlasMatt
                            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                            by PlasMatt
                            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                            09-20-2025, 06:50 PM
                            GeForce RTX2080 Super Aero video gaming card issues help need
                            by sam_sam_sam
                            This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                            Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                            05-07-2023, 08:12 AM
                            HP ProBook 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook 400 Specification for Upgrade or Repair
                            This specification for the HP ProBook 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                            09-06-2024, 06:20 AM
                            HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook 1000 Specification for Upgrade or Repair
                            This specification for the HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
