Toshiba LCD 22BL502B Solid Green Led No Picture
    Re: Toshiba LCD 22BL502B Solid Green Led No Picture
    It's a little different unfortunately.
    Most LED drivers in LED TVs work by using multiple parallel strips driven from a high voltage for example 30V.
    This means there may be 4 strips (CH1-4) and the anode is tied to the fixed voltage, cathode goes to a constant current sink circuit which drops a small voltage to keep the current through each strip the same. You can't tie them in parallel because they are slightly mis-matched: one will take all the current leaving none for the others.
    I don't know of any commercial drivers that are able to replicate that crucial last part, BUT, you could probably use a resistor in place if you knew the approximate power usage.
    For example say the LED strip operates at 27VDC @ 350mA (approx 8 LEDs per CH.) If you run it at 30V, you need a resistor rated at (30-27)/0.35 = 8.5 ohms (nearest: 8.2 ohms, 10 ohms). Such a resistor will dissipate a power of around 1 watt. Choose 2 watt for safety and longevity.
    There are a lot of "if", "ands" and "buts" about this, but it would work, if you were prepared to tweak the operation carefully. I would start at around 20~100mA, and increase until acceptable screen brightness is observed.
    • tanz0
      • Nov 2013
      • 31
      Thanks.
      I understand what you're saying however there is another item here, which is apparently a direct replacement for the screen in question, although I haven't managed to see any part such as this on the assembly. Anyway it has 5 pairs of GND/VCC connections, which I'm assuming are in parallel ? Unless the circuit is performing the current adjustment you speak of.
      Thanks.
      • tanz0
        • Nov 2013
        • 31
        Link !
        http://www.iccfl.com/product_info.php?products_id=16181
          Those appear to be the inputs, and it takes 24V input.
          • tanz0
            • Nov 2013
            • 31
            I think those are the outputs. The other connector is a 6-pin which the screen currently has for a backlight connector. Would you need 5 parallel 24v inputs and separate GNDs ?
            I did notice the 24v but I thought might auto-adjust or assumed it was for 24v. I think you mentioned at the start this model operated on 12v/24v.
            Thanks.
            • tanz0
              • Nov 2013
              • 31
              The glass forming part of the actual LCD display. How important is that ? Minor crack. Is this just to protect internals or does the glass actually play a part in image generation. Something about substrate with electrodes.
              Thanks.
              • DarrenHD
                Firmware for older Toshiba TV 22CV100U
                by DarrenHD
                HI all, Does anyone know if there exists an archive for older firmwares for Toshiba TV's? I've searched all over Toshiba's various websites and also on Dynabook's site (they say they deleted all old firmwares due to "server space". ) Toshiba has not replied to my request.
                I'm looking for Firmware 1.07 for the 19/22/26/32 C100U series as described in this link:
                https://support.dynabook.com/support...tentId=2865076
                Thanks!
                06-16-2025, 11:56 AM
                09-06-2024, 05:27 AM
              • lberkani
                Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
                by lberkani
                I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
                The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
                The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
                I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
                - Toshiba 65UL2163DG
                - Vestel 17MB180E mainboard
                - Panel VES650QNTX-N2-N42
                - Version V1.28.100.0 if available
                If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
                11-11-2025, 12:37 PM
                09-06-2024, 05:59 AM
