Toshiba 32WLG66 - off after 10 sec.
    Hi Folks -
    first of all - i am from germany - and my english ist not as well as my german ... so please be patient ...
    try to save an "old" Toshi LCD TV 32WLG66 which does not work the way he should do.
    whats up with it:
    - Power on
    - TV starts (relaise close on PSU)
    - after 2-3 sec black screen turns on to noise-screen
    - after another 4-5 sec screen goes black (backlight off)
    - after another 3-5 seconds main relais @ psu disconnect and tv is OFF
    thats just happen when i press the power button.
    something curious is also happen when i press the power button -
    and after the screen lights up - press the volume up or down ...
    or the channel up or channel down button
    (that iniate some kind of input trigger for "something")...
    the toshiba stays on - as long as i press one of those buttons ...
    if i left all alone again ... 4 seconds on - 4 seconds without backlight - and than off again.
    thats what i could say about it and what i found out wihtout any tools.
    well by using a screwdriver - i got a look inside the "machine" ....
    unremarkable ...
    so i start looking in the WWW for similar faults on such a TV
    - nothing found - only one TV @ ebay for sale with the same problem.
    so i thought by changing the board which is connected to the IR-reciever respective the buttons @ the TV panel would help.
    Toshiba Signal Board PE0081 HDMI - found @ ebay
    - *click* -bought
    - *click* paid
    - recieve - mounted - and ---- nothing - same problem.
    so i talked to a friend - he told me that he had some similar
    problem with an other brand (not sure samsung? doesn't matter)
    - and in his case the inverterbooard was the couse.
    so - i ordered a new inverterboard - but .... yes - the problem was NOT solved...
    all things are the same ... TV on - do noting .... 5 seconds + 5 seconds = off
    press and hold a key on the remote or the panel ....
    stays on as long as i hold my finger on it.
    i still think it is a small problem - which can be repaired.
    a technician @ toshiba told me something about the i2c bus ...
    and that some kind of signal iss missing - or one signal is disturbing the permantly control of the system ...
    but that was on the phone - so it is a bit like the "christal-ball-voodoo" wihtout any measur ....
    so i found the badcaps.net ... and i hope you have any ideas what i can also do to fix this nice and fine TV...
    thx and best regards from Germany / Hamburg
    polarie
    Re: Toshiba 32WLG66 - off after 10 sec.
    Hi folks -
    now after vacation i have a little time again to have a nother look at this tv.
    just have another question:
    is it possible to "deactivate" the backlight control / monitoring?
    background:
    in earlier times i was in a forum that fixes and pimp video-projectors.
    and all projectors have a bulp-control - and withuot the lamp the projectors does not start.
    so often for testing - we bridged the optical coupler - the get a "patient" running again for some tests.
    i had a closer look at the CCFL's and they are not all equal bright ...
    so i think that one or two of them are End-of-live ... but still shining.
    and the backlight control recognize this - and shut the tv down.
    possile to deactivate or bridge this controll for testing?
    kind regards
    polarie
      I think I may have a similar problem with my 46XV540U.
      https://www.badcaps.net/forum/showth...ht=Toshiba+LCD
      Max
