Problem with Samsung ps43d490 PDP
    replied
    Re: Problem with Samsung ps43d490 PDP
    Just to make sure, could you share a picture of the exact fault in question.
  • Sabenhaz
    replied
    Thanks Tom
    Damm after all my hard work to get it working that happens..
    Sab
  • Sabenhaz
    replied
    Not while it was on but a couple of mins later...surely not! Not after all my hard work
    replied
    Did you plug that cable in while the set was running or shortly afterwards...
    You probably just fried the plasma panel if so. (Sorry!)
  • Sabenhaz
    replied
    Ok scratch that last message. Silly me left the connector between the bottom two buffers disconnected
    Anyway now I have a fine black line going from left to right all the way across the screen. About two thirds the way down...Any suggestions?
    Cheers
    Sab
    replied
    Could you share a picture of the exact fault?
  • Sabenhaz
    replied
    Hi all
    Hoping someone can help. Have been messing around with this telly and replaced most parts
    Clicking 5 times then nothing. Lastly replaced the x board and now thats stopped the clicking but only have half the picture...The right side as you look at it...Any ideas
    Cheers
    Sabenhaz
  • guy_hall
    replied
    It seems to have worked, I have given it about 5 hrs of testing and had no issues compared to 10mins max before but time will tell. It's certainly done something and hopefully it helps someone else too.
    replied
    Useful video, thanks. Hope it works for you. Never heard of this problem before.
  • guy_hall
    replied
    http://youtu.be/PC1Fo1Huipg
    replied
    Could you link us to this video...?
  • guy_hall
    replied
    Just for info, before I just did this, voltages were round 207 and 58 on standby, as soon at I took it out of standby, the voltages dropped slowly and the screen didn't come on. I have also updated the firmware now the screen is working a bit In case there was an issue there
  • guy_hall
    replied
    I watched a video on YouTube about this model shutting down, for him it ended up being bad solder joints on the 42dh ym so I took it off, re soldered most of the joints, put it back in ant it is working at the minute. I refined the voltages using the pots, now I'm just waiting to see if it goes off, while having a go on the ps3 hope the picture uploads properly
    The heatsinks on the transistors get red hot though, don't know if that normal
    replied
    OK, time to take the cover off your TV and get some nice clear pictures of the boards in your set.
    I ask for the boards in your set because Samsung changed the design of this TV mid way through production so your TV could have one set of boards or another.
  • guy_hall
    replied
    I have just tried to turn it on and the screen won't come on at all now. When I give power from the wall, the standby light is on. When I press the power light on the remote, the red light flashes on and off every second but the screen stays off, no luminance / glow at all from the tv?
    replied
    When the screen goes black, does the minimum luminescence (low "black glow") continue to be visible, or does that go too?
  • guy_hall
    replied
    Just watched about 5 mins of a hd film on hdmi then screen went black but sound still there. Turned tv off and on again, sound comes back but screen doesn't. Are there any caps that could affect this before I replace the board?
  • guy_hall
    replied
    Yes, I turn it on and the screen comes on. It lest you watch for a bit then goes off and doesn't come back on for a while. It's worse on he channels. Sometimes only lasts for a few minutes. I had similar on my other lg and replaced the capacitors on the main board and it's been fine since (those weren't domed) but this one doesn't have any on its main board...
    replied
    Sounds possibly like a main board issue... So occasionally, the TV -does- work?
  • guy_hall
    replied
    I have similar problems with a ps43d450a2wxxu. There is sound and some times the screen comes on for a bit then goes off, other times it won't come on.
    If I have all boards plugged in, y&x buzz (x more) and va is 58 and vs is 208. The green light in the logic board flashes every second. If I unplug x main, it comes on for 5 seconds and off for 2, and the boards stop buzzing. Also, with either x, y or both unplugged from the psu, the voltage drops from 58 and 208 down to zero over a few seconds.
    I cannot see any bulging caps but that doesn't always mean they are fine.
    09-07-2024, 05:50 AM
    09-06-2024, 11:40 PM
    09-06-2024, 08:40 PM
    Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
    This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-06-2024, 06:20 PM
