Samsung PN42C450 Sustain Boards
  • rcewilson
    • 8
    Both The X and Y boards seems to have shorted transistors. Is this common?
    If they are unplugged I do get the startup audio sound.
    Re: Samsung PN42C450 Sustain Boards
    I've seen the X board go so yeah, seems fairly common. These TVs are built right down to the last cent so it's fairly common to get shorted semis on them.
    • rcewilson
      • 8
      I'm trying to figure out if it's worth fooling with. Two boards are bad at least. Would I expect the buffers to be bad also? Or maybe something else I haven't thought of.
        You can do a resistance check on the buffers. They might be okay.
        • rcewilson
          • 8
          Can you give me some hints on how to check out the buffer board? I do not have the service manual.
            SM for PS42C430 - maybe same/very similar?
            http://www.tgohome.com/ServiceManual..._src=AltSearch
            Can you please post a picture of your buffer boards.
            • rcewilson
              • 8
              Yes, you are correct. It does look the the 42" model in the manual you listed.
              • rcewilson
                • 8
                Let me clarify that.
                In the Samsung_PS42C430_Disassembly & Reassembly_[SM].pdf it looks the same. The buffer board has the three connector near the bottom of the board.
                I can still post a picture if needed. Thanks for pointing out this manual.
                  If possible can you post a closer picture of the buffers so I can highlight where to test for shorts.
                  • rcewilson
                    • 8
                    Here are the pictures.
                    • electronicsurplus
                      • 210
                      On the connector of the buffer you will see 2 of the pins which are separated from the rest on one end (These are positive) and, there are most grouped together (These are grounds) check between these points. In one direction you should get infinite and the other anywhere above 500k using diode check on a multimeter.
                      If they read anything less then it is shorted (Very common)
                      This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
                      Help keep these from the landfills
                      • rcewilson
                        • 8
                        I don't seem to see this. All three connector have pins that are equally spaced just like the one I photographed.
                          You need to be looking at the copper traces on the board itself. The lighter green lines.
                          • rcewilson
                            • 8
                            OK maybe the buffer board is bad also. In that case I am giving up on this one as it needs three boards plus I don't have the remote. Just not worth the cost for me. This model built in Oct 2010 must have cut too many corners in trying to be more competitive.
                            Thanks for your help. I did learn a few things at least. Maybe next time it will turn out better.
                              09-07-2024, 05:50 AM
                            • Yanleb
                              Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                              by Yanleb
                              Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                              If they are not compatible why did Samsung give them the same part number to begin with?
                              08-04-2025, 11:35 PM
                              09-06-2024, 11:40 PM
                              09-06-2024, 08:40 PM
