samsung ps50a476p1dxxu fault need help
  • essex1
    • May 2012
    hi i have a 50inch plasma and they aper to be a fualt with the picture its very hazey tryed everything from adjusting from the board on the back but no different they is also red lines in the black im lost at what to do now any help would be grate
    Re: samsung ps50a476p1dxxu fault need help
    Z-sustain/X-main probably... seen it on the C450 series.
    • essex1
      • May 2012
      hi thank you thou your prompt repley is this an expensive fix and is they anything i can do to make it more watchable in the mean wile
        First question, depends on what you define expensive as, probably around £60. If you are handy with a soldering iron and a multimeter, you can sometimes do component level repair - so around £10.
        Second question, no unfortunately not, as the Z-sustain's job is to drive the plasma panel - in conjunction with the Y-sustain. Without it the plasma doesn't discharge properly and you don't get a proper picture. On some LG sets you can get away with a dim, grey/purple picture, but it's not much to watch. It is responsible for sustain (lighting the panel), as well as the some of the erase and reset waveforms.
        • howardc64
          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
          by howardc64
          • Prior owner tried a replacement main board. No difference.
          • Samsung 2x red blinking standby LED = panel fault
          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
          07-19-2025, 10:54 PM
          09-07-2024, 05:50 AM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
