Samsung PS50B430 Y-main Fault?
  • netdent
    • May 2011
    • 208
    I have this samsung plasma, came to me with clicking syndrome! Narrowed it down to the y main board, on closer inspection on the y board small 1 amp fuse open, never had solder in fuse to hand so soldered 2 wires and crock clipped 1amp fuse inline, powered on no clicking but an smd resistor smoked slightly followed by clicking psu again, fuse remained intact! the voltage across the fuse is 15 volts.
    I removed the y board and found a shorted fet circled red in picture IRFP4332 there are 2 of these the other read ok, I replaced the shorted fet and fitted back in, the set powers on and makes the right noises but screen is blank. I'm thinking still a problem on this board? all psu voltages read correct
    The previous owner changed the LDVS board, and also tried to fit an incorrect y board? but think there was no damaged caused by this.
    not sure where to go now, maybe the smoking resistor is toast? difficult to get at with the heatsink, any advice welcome
    thanks Ronnie
    sigpic
  • PlainBill
    • Feb 2009
    • 7034
    Re: Samsung PS50B430 Y-main Fault?
    thanks Ronnie
    Definitely a problem with the Y main. Yes, it could be the resistor, or it could be some other problem. Troubleshooting these are very difficult due to a lack of schematics and the fact that they deal with high frequency (200 Mhz), high voltage (>200 volt) signals.
    PlainBill
    • netdent
      • May 2011
      • 208
      PlainBill
      Thanks PlainBill, might need to try and source a used part? not sure if I will be able to read the value of the resistor if it is open, guess it will also need to be read out of the board
      Ronnie
      sigpic
      • howardc64
        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
        by howardc64
        • Prior owner tried a replacement main board. No difference.
        • Samsung 2x red blinking standby LED = panel fault
        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
        07-19-2025, 10:54 PM
        09-07-2024, 05:50 AM
      • jesterace
        Samsung UE46ES8000 Blown fuse but no other signs of short
        by jesterace
        Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
        09-11-2024, 03:14 PM
        09-06-2024, 11:40 PM
