toshiba regza problems
  • timwebb22
    • Jan 2011
    • 30
    • united states
    hi everyone.been reading here for a while...ok i have this tv and it came from a pawn shop it was left on all the time and. a few days ago the screen stopped coming on. the tv turns on and off. but nothing from the screen. im thinking its the inverter.just wanted to see what should i check.thanks!
  • PlainBill
    • Feb 2009
    • 7034
    Re: toshiba regza problems
    Check the power and control voltages to the inverter; also check the fuse.
    PlainBill
    • timwebb22
      • Jan 2011
      • 30
      • united states
      i checked the wires going to the inverter.there is no voltage going in to it.
      • PlainBill
        • Feb 2009
        • 7034
        See if the power supply is putting out the correct voltages.
        PlainBill
        • timwebb22
          • Jan 2011
          • 30
          • united states
          the two connectors at the top goes to the inverter.that reads nothing.
          the two at the bottom have correct voltages.
          • PlainBill
            • Feb 2009
            • 7034
            It sounds like the main supply isn't turning on. To troubleshoot this we are going to have to start at the beginning.
            I'm going to need 3 pictures. I would like them to be at least 1000 x 1000 pixels; the site has a 2000 pixel limit, so don't go over that. It also helps if you can do this without flash.
            The first picture is a little less critical - I need a picture of the back of the TV, showing where the cables go. The next two are more important. The first should be of the top of the power supply, but no flash, please. The second should be of the bottom; again, no flash. If there are any indications of the functions of the pins on the cables, it would REALLY help if that information is readable.
            PlainBill
            • timwebb22
              • Jan 2011
              • 30
              • united states
              • timwebb22
                • Jan 2011
                • 30
                • united states
                more
                • timwebb22
                  • Jan 2011
                  • 30
                  • united states
                  more...
                  • timwebb22
                    • Jan 2011
                    • 30
                    • united states
                    these pic good?
                    • PlainBill
                      • Feb 2009
                      • 7034
                      these pic good?
                      Not good enough. Bluntly, this is the sort of thing that makes me want to go play 'Angry Birds', cut down a tree, or download porn.
                      This was my request:
                      I asked for three pictures, I got seven. The first one was what I wanted - it showed the boards and the interconnections. The second showed the connectors, and it even showed the labels indicating the signals on each line - except they were obscured by the wires!!! As far as the overall shot of the top - useable, but not great. And for the picture of the bottom side of the power supply - nothing. Which is exactly the response I gave you.
                      PlainBill
                      • timwebb22
                        • Jan 2011
                        • 30
                        • united states
                        sorry about that. i thought it uploaded.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Ouch!!!! What happened to the lower left corner of that board? That circuitry should control the main supply.
                          The 8 pin connector in the upper left area of the board appears to be P806. Pins 1, 2, and 3 are control signals.What does it say about those pins on the top of the board?
                          PlainBill
                          • timwebb22
                            • Jan 2011
                            • 30
                            • united states
                            it looked like that spot was repaired.
                            here's the 8 pin plug.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              What is the voltage on pin 3 of the 8 pin connector (use pin 3 as the ground point). Test with the TV plugged in, and the TV switched off, then on.
                              PlainBill
                              • timwebb22
                                • Jan 2011
                                • 30
                                • united states
                                3.25v
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  3.25v
                                  With the TV on and off? (I'm not a mind reader.)
                                  A wee bit of information. This TV has a dual power supply. The standby supply is on whenever the TV is plugged in. The output of the standby supply powers a small part of the main board which 'looks' for signals from the remote - such as the power button being pressed.
                                  When the power button is pressed on either the remote or the front pane of the TV, the main board sends a signal to the power supply, turning on the main supply. The joker is the 'power control' signal varies from manufacturer to manufacturer and from model to model. USUALLY it's called PS_ON; and if it's at 3.25 volts, the main board is turning the main power supply on. One set I was working on recently called it 'Standby', and when it was high, it turned the main supply off. These jokers call it 'Power_Sig'.
                                  The idea is, if it changes every time you press the power button, but the power supply never comes up, it's a power supply problem. If it never changes, it's a main board problem.
                                  Just to make things more interesting, about midway between the 6 pin connecotr and the transformer labeled TDK X 0729 is a short reddish brown cylinder. That is a fuse. Check it. Look for other fuses and check them.
                                  PlainBill
                                  • timwebb22
                                    • Jan 2011
                                    • 30
                                    • united states
                                    oh.with the tv on.
                                    • timwebb22
                                      • Jan 2011
                                      • 30
                                      • united states
                                      ok. i redid the test cause i noticed my meter wasn't functioning like it should.so i went and got my fluke and got a different reading. 44.1v. i know i should have used the fluke in the first place.
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        oh.with the tv on.
                                        OK, I described the two possible behaviors above. You're on your own.
                                        PlainBill
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                          09-06-2024, 05:33 AM
